Author Topic: decking head ? cb550k  (Read 746 times)
Offline Roach
« on: April 24, 2011, 01:42:50 PM »
so i have been having problems with head gaskets as of late
so i am going to get my head and jugs decked
how much should i be looking to pay to have this done?
will the shop be able to port and polish my head at the same time?
will my stock valves be able to go back in after port and polishing?
1978 CB550K Cafe Racer
Offline bikebitzofvt
Re: decking head ? cb550k
« Reply #1 on: April 25, 2011, 12:03:07 PM »
What brand gaskets have you been using?
I happen to have my local machine shop's price list right here - getting ready to get my 836 kit in my 750...
He gets $42.50 (+ $0.09 per .001") to remove material from a head.  I'm not sure if he uses his milling machine or surface grinder.  Lists $50.00 for deck surface clean up.  You'd have to find someone in your area to see what their skills are and if you feel comfortable with them porting / polishing on your cylinder head.  You should be able to keep your valves as they are, they might need a refacing and/ or new seals.  MRieck is the local porting guru on SOHC4, many on the site rave about his work.
Most polishing (exhaust side only) can be done at home with a dremel tool.  Matching ports can be a small increase in power and also done at home.  Porting, really getting in there and removing material, can actually be more detrimental than helpful without having seen what the changes will make on a flowbench.  On 2 valve Ducati heads I actually added material to the bottom of the intake ports and made 7+ HP 10+ Ft lb tourqe.
Paulages built an astonishing 550 / 650 hybrid.  Track down his build thread, theres a ton of info there.  I recall reading a stock 650 head will flow better than a ported / polished 550 head, but then again my memory ain't what it used to be!
If you go the decking route I have no idea what amount is safe to remove.  I'd like to get an idea for my 750 engine, too.  Whenever material is removed from this area the valve to piston clearance must be checked, usually with clay on the top of the pistons.
Good luck!
« Last Edit: April 25, 2011, 12:07:01 PM by bikebitzofvt »
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
