Author Topic: CB400F pistons in a CB350F  (Read 1642 times)
Offline jsedacca
« on: April 25, 2011, 12:31:20 PM »
Hey guys,
     I'm currently in the midst of my cb350f engine build. I have stock CB400F pistons (51mm) that I plan to use. From what I gathered, this is the maximum size to bore out the cb350f jugs. My main question is, is there anything that needs to be done to the combustion chamber area of the cb350f head? I'm assuming I'll need to use a CB400f base gasket but what about the head gasket? Any help/insight would be greatly appreciated. Thanks
                                                     Jared
Offline fmctm1sw
Re: CB400F pistons in a CB350F
« Reply #1 on: April 25, 2011, 01:43:40 PM »
Hey guys,
                                                     Jared
Something tells me the valves were different.  Other than that, not sure...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: April 25, 2011, 02:28:19 PM »
Yes you can fit the std 400F pistons (51mm) to the 350F. This will leave you with a wall thickness of 2.0mm on the sleeves, this is borderline but I have done it. The last one I did I sleeved it with new sleeves to allow an over bore if required later.
You can use the CB350F base gasket, but you will have to fit a custom copper head gasket. Combustion chambers OK as they are. The 350F valves are smaller than the 400F. you could fit std 400F valves if you are going to do a head job.
350F Valves:
Inlet: 26.0mm
Exhaust: 22.0mm
CB400F Valves:
Inlet: 26.5mm
Exhaust:23.0mm
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline jsedacca
« Reply #3 on: April 25, 2011, 03:59:51 PM »
That was the answer I was looking/hoping for. Thank you
Offline jacksonc
« Reply #4 on: April 25, 2011, 08:50:10 PM »
I've got a 400 and it isn't like super powerful or anything :) I'd get some jugs from a 400 and put in the 460 kits, then you'd have a really big 350
