Author Topic: Front Axle removal Quest.  (Read 1905 times)
Offline GEO
« on: April 25, 2011, 04:57:06 PM »
Can anyone pleas explain to me how to remove the front axle from the hub assembly/speedo drive. The bike is a 77 CB550F. My initial attempt was to beat it senseless until it came out, however I took a step back and decide to ask for help. I did search it out and had no luck.
Thank you, GEO
Offline meb1948
Re: Front Axle removal Quest.
« Reply #1 on: May 01, 2011, 05:15:14 AM »
I had the same problem with a front axle on a 76 750 hub.  I was able to remove the bearing retainer with its rubber dust seal then use penetrating oil and heat from a propane torch to remove the axle.  The collar was stuck to the axle with what appeared to be carbon.  The bearing had failed which must have heated the area and cooked whatever was between the collar and the axle.
Heating the collar allowed me to knock the axle free with a mallet.
Now I'm wrestling with a 400F front axle.  The bearings seem to be fine, but the axle is not sliding out like it should.
I'm in the process of removing the bearing retainer then plan to take a hard look at the collar.  I've already found rust on the axle nut and in the general area of the collar.  I plan to use the same approach with the penetrating oil and heat once I remove the bearing retainer.
Both of the wheels I mention were purchased on EBay and are used as spares so I had/have time to work on them.  Care needs to be taken when using the torch because of the close proximity of the aluminum hub to the heat source.
Mark
Mark
1976 Honda 400f
1976 Honda 750f1
1980 Kawasaki KZ1000
1989 Saleen SSC #170
2001 Mustang Cobra Convertable
Offline Grabcon
« Reply #2 on: May 01, 2011, 05:50:34 AM »
Can I assume that to remove the axle that you unscrewed the end prior to thinking about beating on it? If not try that then the axle should push through.
This forum has all the manuals. You should download and look at them.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
