Author Topic: 13mm Master Cylinder? Will Any do?  (Read 1860 times)
Offline ntm1974
« on: April 26, 2011, 05:26:11 PM »
Will any 13mm master cylidner do for a single disk front brake on a 74 cb350F?  I've seen some with brake light switch wires sticking out.  Is that an issue or can I just tape them up and forget about them when using them on a cb350f?
Thanks for looking.
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: 13mm Master Cylinder? Will Any do?
« Reply #1 on: April 26, 2011, 05:38:41 PM »
Providing you have the correct brake lines, any 13mm master cylinder will do.
Consider one with a mirror mount if necessary, and use the electronic brake light switch too, if they come with one.
Gives you the opertunity to run a nice braided line direct to the caliper.
