Author Topic: Dorothy III - CB750  (Read 105892 times)
Re: Dorothy III - CB750
« Reply #200 on: October 19, 2013, 03:59:17 PM »
Looks good mate, can you post a pic of the driver (with dimensions) you made to smack the old bushes out? I have to replace mine soon, so I'd appreciate it. Cheers, Terry. ;D
« Reply #201 on: October 20, 2013, 08:46:14 AM »
Not much to it, just 1/2" steel bar with 3/4" collar welded on it. I put the collar on the bushing and went around hammering it and the bushing moved slowly out.
Hope that helps.
« Reply #202 on: October 21, 2013, 12:29:19 AM »
Thanks mate. ;D
« Reply #203 on: March 09, 2014, 02:58:38 PM »
Drained the oil, changed filter and realized the drain bolt thread is stripped.
The bike came to me with oil drain hole welded shut and I drilled and tapped it to 5/16 thread which was now spinning not free but close enough.
Took the pan off and this time made it M10x1.25, squared and cleaned the sealing surface and found new copper washer.  Hopefully it's gonna last now.  Of course I had to drop headers to get the pan off.
With the dry sump I could actually run it without the drain hole, there is never that much oil in the pan to drain.
Took her for a quick spin, she pulled solid 1.1 ton in 4th gear when I eased off, she has more balls than I do.
« Reply #204 on: March 09, 2014, 03:35:13 PM »
M10 x 1.25 is the standard drain hole size mate, so it should be fine. I wonder why the PO welded it up in the first place? It's definitely worthwhile having a "sump plug" even in a dry sump, I still get over a litre of oil drain out when I dump mine. Cheers, Terry. ;D
« Reply #205 on: March 09, 2014, 04:05:03 PM »
Thanks! I was wondering about the size, although the M10 felt right:)
« Reply #206 on: March 24, 2014, 08:26:50 AM »
20C on Saturday, took her for a spin and limped home on two cylinders  >:(
Cleaned up idle jets, fuel valve bowl, still the same.
Next step was to check on spark plugs and cables, spark plugs were due for replacement, but the real issue was in cables.  That said I am starting to see the advantage of the old style coils with integrated cables.  The problem was cable to coil on #3 and #4.  I may come up with some better grommet for the plastic finger not to prevent it in the future.
Anyway she is back in shape, the idle drop from 1200 or so to 1000 - not sure if the new plugs (gapped at 0.032") or the clean idle jets.
« Reply #207 on: June 25, 2014, 03:36:56 PM »
Finally build a rack to hold my war trunk from Europe.
« Last Edit: June 26, 2014, 05:00:22 AM by 70CB750 »
« Reply #208 on: June 25, 2014, 03:38:53 PM »
That bike is going to wheelie with little effort!!
« Reply #209 on: June 25, 2014, 03:42:56 PM »
Yeah, those 15 pounds the trunk can carry will easily sweep my 260 of the ground.
Offline dhall57
« Reply #210 on: June 25, 2014, 03:59:37 PM »
Now that's a trunk ??? You sure you aren't hiding a body in there Pro ;D
Looks like you still need a seat.
« Last Edit: June 25, 2014, 04:25:36 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #211 on: June 25, 2014, 04:13:48 PM »
Haha.  I was assuming you were loading that sucker up with some gold bars!  It should carry more than a measly 15 lbs.  Probably more like a carry on.
« Reply #212 on: June 25, 2014, 05:26:43 PM »
That trunk saw more European countries than average American.
Colleague of mine asked me today if there is a collection going on to get me new seat. The new seat I have, but the PO cut off original hinges and I would have to weld the frame to fix it. It has to wait for frame up.
« Reply #213 on: June 25, 2014, 07:33:34 PM »
I'll donate 20 bucks!   C'mon man
« Reply #214 on: June 25, 2014, 07:46:34 PM »
yeah! that seat is looking pretty steampunk!
« Reply #215 on: June 26, 2014, 02:39:04 PM »
This is to show what the PPO or the PPPO done to the seat.
« Reply #216 on: June 26, 2014, 03:15:35 PM »
I know the CO [current owner] could do a better job!
« Reply #217 on: June 26, 2014, 03:29:33 PM »
Thank you :)
Offline fastbroshi
  • Puppet
« Reply #218 on: June 27, 2014, 07:13:56 AM »
Either that table is Chinese or it's gotten a little too close to the sun!  That's about the worst bow I've seen in a table.
Just call me Timmaaaaay!!!
« Reply #219 on: June 27, 2014, 07:15:20 AM »
Treated lumber, is it something or what?
Offline fastbroshi
  • Puppet
« Reply #220 on: June 27, 2014, 07:51:25 AM »
Oh I see, that jug must be filled with some super dense unobtanium anti-matter and weighs 3 tons (see "Terry's ass" in the dictionary).
« Reply #221 on: June 30, 2014, 10:21:26 PM »
Hey hey hey, that's not my arse, that's my massive balls! ;D
« Reply #222 on: July 01, 2014, 03:35:36 AM »
Thanks for the classy input, guys  ;D ;D ;D
Offline vfourfreak
  • Do you think that's wise
« Reply #223 on: July 01, 2014, 06:18:03 AM »
Massive gonads Terry, but no dick !
Sorry Prokop, back to the build . . .
Kev
« Reply #224 on: July 02, 2014, 11:47:09 PM »
Kev
At my age, it's really not that necessary Kev.......... ;D
