Author Topic: Dorothy III - CB750  (Read 103675 times)
0 Members and 7 Guests are viewing this topic.
Online Stev-o
Re: Dorothy III - CB750
« Reply #350 on: October 05, 2015, 07:05:33 AM »
You apply for a patent?!
« Reply #351 on: October 05, 2015, 07:07:52 AM »
No, I will return my engineering degree; it should have been obvious from the very beginning  >:(
Offline calj737
  • I refuse...
« Reply #352 on: October 05, 2015, 07:40:29 AM »
Nobody ever accused engineers of being practical thinkers  ;D
« Reply #353 on: October 06, 2015, 01:43:20 AM »
Cool!  Go Prokop go.
« Reply #354 on: October 06, 2015, 04:36:20 AM »
Thank you  :)
There is nothing like complete tear down to understand what is inside.
Also my first real job ever was production engineer in die and tool factory; we made molds for casting aluminum, including molds for Yezdi:
https://en.wikipedia.org/wiki/Yezdi_Roadking
but the Honda cast is pretty amazing.  You can see some flow problems here and there, still hard to believe they molded them in sand in actual production - even limited production.
« Reply #355 on: October 19, 2015, 04:02:23 AM »
Hanging continues, need the space and resources for other projects.
Offline MoMo
  • Ride like you're invisible
« Reply #356 on: October 19, 2015, 08:27:18 AM »
So you got hung out to dry??? ::)
bad jokes are my forte, hope all is well...larry
« Reply #357 on: October 19, 2015, 03:51:41 PM »
I think he just wants a well hung motor.
« Reply #358 on: October 19, 2015, 04:19:15 PM »
Ha!  Very good. All I could come up was hanging my spurs or hanging my guns :)
The rest of Dorothy is wrapped and labeled and stored.
Online Stev-o
« Reply #359 on: October 19, 2015, 04:32:52 PM »
Waiting for a rainy day?
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #360 on: October 19, 2015, 05:01:40 PM »
Sure hope it wasn't a lynching party we weren't invited to.
Charlie
Online Stev-o
« Reply #361 on: October 19, 2015, 05:44:04 PM »
If it was a lynching of a SOHC, I think the outcome would be different!
« Reply #362 on: October 20, 2015, 02:16:14 AM »
Something like that  ;)
« Reply #363 on: November 02, 2015, 06:10:25 AM »
Played some with "modern" bike parts - 1993 VFR fork and brakes.  I was able to mock my "sidecar" wheel together in the VFR fork and VFR brake caliper.  Sidecar wheel is CB750 front wheel with bearings upgraded to ID 20mm.
I never felt like going to 17" wheels on Dorothy, but seems like I have a plan now:
- Custom triple tree, VFR fork and brakes, 19" front wheel with original dual discs - thinned.
- 18" wheel for the back, original swingarm and decent shocks, unless I can find aluminum swingarm that fits 18" wheels. Drum brake for the rear wheel.
- DID rims or aluminum, depends what I can find.
The whole idea is for Dorothy to look like mild custom cafe with performance upgrades hidden in plain sight.
Opinions?
« Reply #364 on: November 02, 2015, 09:15:59 AM »
Seems like Suzuki GS1100 will do:
Offline calj737
  • I refuse...
« Reply #365 on: November 02, 2015, 09:54:48 AM »
Are you planning on staying with drum rear and a sidecar?
« Reply #366 on: November 02, 2015, 09:56:10 AM »
Sidecar will be for the K3F.
Offline calj737
  • I refuse...
« Reply #367 on: November 02, 2015, 09:56:50 AM »
Mea culpa
« Reply #368 on: November 02, 2015, 09:58:05 AM »
Not at all.    ;D
I want two bikes - one for travelling in two or three or just me a and a dog  ;D- second to ride solo.
Online Stev-o
« Reply #369 on: November 02, 2015, 01:45:34 PM »
Have you thought about using a GL front end? Has dual disc and the wheel may be alum[?]
« Reply #370 on: November 02, 2015, 02:56:30 PM »
Info for the GS1100 arm, they have a larger diameter pivot bolt , mods needed to frame to fit, they aren't as wide at the pivot end as the 750 stock are, spacers needed to fit, they are also nearly 4 inches longer. I have one i'm using but it will be shortened at the pivot end to retain stock geometry.. The lower shock mounts are also in a wider position on the GS arm, Brake arm is on the top which works great for a disc application, not so much with drum, more mods needed.  Its no where near a bolt in fit... It is a nice arm though....
« Reply #371 on: November 02, 2015, 03:33:10 PM »
Thank you for the info, much appreciated!
« Reply #372 on: November 02, 2015, 03:34:55 PM »
Too easy, I Have a GS1100 arm sitting next to me beside the computer...
Online Stev-o
« Reply #373 on: November 02, 2015, 03:50:53 PM »
Bolt that thing up and get a roller going Mick!
« Reply #374 on: November 02, 2015, 03:55:17 PM »
Yes I did, but than I found these VFR elements and they seem to be a good choice.  Like those calipers will work with original K discs, headlight brackets I have will fit VFR forks, seems kind of clicking together if you know what I mean.
