Author Topic: Dorothy III - CB750  (Read 89089 times)
70CB750 and 4 Guests are viewing this topic.
Online 70CB750
Re: Dorothy III - CB750
« Reply #500 on: July 09, 2024, 04:27:52 am »
You gotta love the 1,001 uses for angle iron! Such a versatile material shape.
Exactly.
Online 70CB750
« Reply #501 on: July 09, 2024, 04:36:02 am »
Truing the wheel I started to freak out.  It seemed like I will never get it right.
This morning  I took a dial indicator to see how bad it was.
0.74 mm axial and 1.2mm radial.  I can live with that.   :)
For the kicks I checked the old rim from Dorothy. 2.7 mm and 1.35mm.
Offline grcamna2
« Reply #502 on: July 09, 2024, 07:05:54 am »
Prokop,have a look at putting the pointer inside the rim,along the bead area;that area is the most accurate.
Online 70CB750
« Reply #503 on: July 09, 2024, 07:46:20 am »
Thats what i did.
Offline BenelliSEI
  • 1969 cb750
« Reply #504 on: July 10, 2024, 06:32:54 am »
Still truing the rim.  Finally made me a truing stand.
[/quote
How do you stop the axle from shifting left or right?
P.S. I pulled two old metal bed frames out of a scrap bin last week. Great source of free material!
Online 70CB750
« Reply #505 on: July 10, 2024, 07:08:30 am »
I pulled many things from the scrap bin - even though it is illegal in our county.
I wrapped masking tape on the axle and that helped.   For the final check I held the axle and let it spin on wheel bearings.
If there is a trick to it, I am all ears, sir.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #506 on: July 10, 2024, 07:52:13 am »
Frustrating, are the bearings ok?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #507 on: July 10, 2024, 08:19:20 am »
20-30+ yrs. ago persons could walk around the county landfill areas without anyone telling them 'that's against the rules'. Very upsetting how they have messed things up now.
Prokop,what's their reason for saying it's illegal to remove an item ?
Offline calj737
  • I refuse...
« Reply #508 on: July 10, 2024, 08:20:50 am »
What you could have done, is move the rollers to the inside of the angle iron at the proper width of the axle spacer to hold the rim/hub centrally. Then lateral movement would have been restricted. But tape works perfectly well for the tolerances you need and you achieved even better than necessary truing.
Online 70CB750
« Reply #509 on: July 10, 2024, 11:09:58 am »
There used to be trash-to-treasure sharing area at the landfill but some people would hang there all weekend to get items for yard sales and such.  Now you can leave it and it gets donated to a local thrift store and money from the sale goes to the county food bank.
But once you drop it in the trash or recycling container, it belongs to the county and it is illegal to take it.
Online 70CB750
« Reply #510 on: July 10, 2024, 11:12:22 am »
Gotit, thanks.  I will make some shaft collars when I have time to play with it.
Online 70CB750
« Reply #511 on: August 20, 2024, 05:55:32 am »
Borrani going tubeless.  I used 3M 5200 glue to seal nipples in and it will get covered by special tape.
« Last Edit: August 20, 2024, 07:17:59 am by 70CB750 »
Offline calj737
  • I refuse...
« Reply #512 on: August 20, 2024, 07:09:55 am »
Have you seen the “foam core” used on newer bicycles for spoked tires? It makes the tire tubeless, plus adds some amount of protection during tire compression. I don’t know whether they have any in 19/18” diameters, but the concept is pretty good.
Online 70CB750
« Reply #513 on: August 20, 2024, 07:18:30 am »
I did not know that, will check it out.
