Author Topic: oil tank build  (Read 2277 times)
Offline rippy154
oil tank build
« on: April 29, 2011, 06:02:55 PM »
For some reason I felt I didn't have enough projects going on so I decided to build an oil tank, I haven't finshed it but will walk you threw where I'm at
1st I went to my drawer full of bungs, some I made some I have bought from www.bungking.com, than I cut an 8" piece of 5" x .120 wall tubing
I than drilled two 3/4" holes 5" apart I also made a quick jig to hold the 3/8 x 16 bungs square while I tacked them
Here it is with the mounting bungs welded in I than moved on to making some frame tabs
I than looked at some end caps I bought at www.bungking.com and decided to go with the domed end caps.. I tacked one on and will leave the other off untill I mount to the frame and drill the oil feed and return holes and the vent and fill just to make it easy to clean out all the metal shavings
Well thats all I got for now
Thanks Stephen
Offline albertaboy
  • No way I'm a
Re: oil tank build
« Reply #1 on: June 10, 2012, 04:57:03 PM »
How's this coming along? I wish I had welding talent.
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
