Author Topic: weighed my bike today  (Read 12461 times)
  • Moderator
Re: weighed my bike today
« Reply #25 on: May 03, 2011, 01:22:27 PM »
Scott, have you any idea what your wheels weigh compaired to stock type wire with aloy rims?
Are your cast wheels aluminum or magnesium?
Sam. ;)
« Reply #26 on: May 03, 2011, 07:08:54 PM »
Sam, my wheels are aluminum. The front wheel, with tire, bearing hubs, bearing spacer, and bolts weighed about 2 pounds more than a stock K7 wheel with the same hardware. The bare Morris wheel, with hubs, spacer, and bolts was around 13.5 pounds. The bare rear wheel, with hubs, spacer, bolts, alloy sprocket, and disc was about 20 pounds.
« Reply #27 on: June 10, 2011, 07:36:52 PM »
The battery tray on the left is my old one, that I made to fit a 3 Ahr lead battery. With the stock reg and rectifier, it weighs 880 grams. The tray on the right is the new one, made to fit the LiFe battery, and weighs in at 260 with regulator and rectifier. I also shaved another 30 grams or so in wire and mounting hardware.
Offline cavebear
« Reply #28 on: June 11, 2011, 03:12:13 AM »
Just being a Seeley is a good start on weight reduction right there. Frame 25 lbs lighter than stock. Adding headers another
15/20 lbs?
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
Offline Jim F
  • go baby go
« Reply #29 on: June 11, 2011, 09:36:11 AM »
Mike,Jim and I tried to weigh it today.Snuck the wife's old spring scale out.Jim lifted the rear,I slipped in scale........Jim PUT it down.....wife don't know her scale no longer accurate...we screwed it up good...that's racing honey! ;) ;D ;D ;D,Bill
I think it weighs less also.I guessed 420.,John 440?,Sam 430?Jim,I forgot. ;D
When I sat the bike down on the scale (Kind of hard) all I could read on the scale was "Oh Sh....t"
Tell Pat I am sorry
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Bill/BentON Racing
    • BentON Racing
« Reply #30 on: June 12, 2011, 07:05:23 AM »
Jim.....you kidding...I'm not saying nuttin!!!!!!! ::) ;)
Am taking bike to work to weigh on our digital scale. ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline voxonda
« Reply #31 on: June 12, 2011, 07:45:56 AM »
Total with half a tank of gas: 194.0 kgs.
Front: 95.5 kgs
Rear:  98.5 kgs
That means a 49.2 / 50.8 % balance.
OEM frame. Think can find a few ounces more, first need to get rid of these heavy disks.
Rob
« Reply #32 on: June 12, 2011, 09:57:27 PM »
Front: 95.5 kgs
Rear:  98.5 kgs
Rob
Rob, was this weight with the self energizing ignition? How much is a half tank? My weight was with an empty fuel tank. My discs are most likely lighter than yours, but my carbs would balance that out.
« Reply #33 on: June 12, 2011, 10:07:22 PM »
Got a newtome Aluminum tank this weekend. Will fit an AMEN frame, its from an RM? 125 I think.
 Weighs 3 ish lbs with petcock and cap, TL Honda one weighs about 4 ish. Think the TL holds abour 1.2 gallons, The RM  looks like a bit more.
 Anyone got a weight on a stock 750 tank, with petcock and cap ?. I am think at least 10 lbs..
« Reply #34 on: June 12, 2011, 10:16:28 PM »
I have a K7 tank I can weigh. I think the alloy Seeley tank is 7-8 pounds?
Offline voxonda
« Reply #35 on: June 13, 2011, 01:40:19 AM »
[/quote]
No self energizing ignition, but with very light battery and Accent ignition. No generator. About 8 kgs of fuel in tank. Disks are thinned and drilled.
Cheers, Rob
« Reply #36 on: June 13, 2011, 08:11:19 PM »
Frank, K7 fuel tank with cap and petcock is 10-11 pounds; good guess.
BTW, I also weighed a K7 oil tank on the accurate scale at a smidge over 3 pounds, but I'm guessing a K1 tank is heavier. The big chrome cap/dipstick alone has to weigh more than the K7 plastic one!
Rob, so no rotor at all, correct? Field and stator are worth over 5 pounds, (I have more exact numbers in grams, but did not bring them home), and rotor is, what, about 5 pounds? The one disc I weighed was 2011 grams.
« Reply #37 on: June 22, 2011, 07:27:59 PM »
I finally got around to making a new starter plug to replace the expandable rubber freeze plug. The new one weighs 14 grams, and the old one is 44.6.
I also found that a K1 front axle is 26 grams lighter than a K7 axle. Every little bit helps! ;D
Offline voxonda
« Reply #38 on: June 29, 2011, 01:26:16 PM »
Made some new chain adjusters for the test-rig. Combo of 6082 adjusters from Kevin @ TTR400 and 7075 adjusterblocks and 2011 bolt. Together with the hollow axle a considerable weight loss.
Will weigh the assy's in the coming days.
« Reply #39 on: June 29, 2011, 07:54:49 PM »
What is 6082?
Been working on new rear-sets: the old right side, with the Seeley mounting plate, John Tickle peg,brake lever and linkage, plus generic passenger peg weighs 3.4 pounds. The left side weighs 2.6 pounds. I think I can shave more than a few grams off here... ;)
« Reply #40 on: June 29, 2011, 10:02:18 PM »
What is 6082?
Here ya go..... ;)
http://www.azom.com/article.aspx?ArticleID=2813
« Reply #41 on: June 29, 2011, 10:16:19 PM »
Thanks Mick!! I have experience with 6061 T-6, and 7075, but never heard of 6082. That link also explained the difference between T-6 and T-651. I have been wondering about that for a while now.
« Reply #42 on: June 29, 2011, 10:37:41 PM »
No worries mate. I really love the shear amount of information on this site, you learn something new every visit..... ;)
Offline voxonda
« Reply #43 on: June 29, 2011, 10:54:05 PM »
Thanks Mick, you were ahead of me.
Cheers, rob
« Reply #44 on: June 29, 2011, 11:08:15 PM »
I know I learn something new almost every visit!!! ;D Thanks again.
Offline Jim F
  • go baby go
« Reply #45 on: June 30, 2011, 05:02:50 AM »
I would like to weld some up and compare that to the normal 60 series and the 70 series
just for laughs and giggles
sounds like some good stuff thought
thanks for posting the link about this material
Jim
« Reply #46 on: July 13, 2011, 07:13:15 PM »
I decided to give cutting my old K1 rotor down a try. Made a tapered arbor (6 degrees, BTW), studied the relationship between the field coil, the rotor, and the stator, and started making chips. The net result is 223 grams lighter than the K7 rotor I have been running, and I believe there will be little or no loss in charging.
« Reply #47 on: July 13, 2011, 09:24:53 PM »
You forgot the big bevel on the inner snout. Then drill out the starter clutch holes to 3/7" and then drill another in between,  6 holes
« Reply #48 on: July 13, 2011, 10:12:01 PM »
I didn't drill out the clutch holes, as I think this would reduce the charging. This is a major path for the magnetic flux from the field through the rotor, the same reason I only beveled the outside edge and not the inside edge. I did put a large bevel on the inner snout.
« Reply #49 on: July 21, 2011, 09:15:34 PM »
Since I had the alternator and shifter covers off already, I cut down my spare K7 shifter cover, CR style, and filed off the asinine shift pattern. (The "Kickstarter" label is even more asinine!!  ::)) The result was another 110 grams off. Now to get back to the rearsets...
