Author Topic: fork tube travel info  (Read 1282 times)
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« on: May 04, 2011, 07:21:43 PM »
Anyone know how much the fork tube travels into the lower piece during road use. Im wanting to know because I would like to remove the chrome(as much as I can). 78 750k
« Last Edit: May 04, 2011, 07:23:21 PM by millerza »
Offline millerza
  • Zach Miller
Re: fork tube travel info
« Reply #1 on: May 04, 2011, 07:28:24 PM »
To clarify, I want the tubes to look brushed instead of chrome, but im guessing removing(blasting to rough) all the chrome would not seal well.
Offline Nikkisixx
« Reply #2 on: May 04, 2011, 07:28:43 PM »
Put a zip tie on the tube just above the slider and ride around for a bit.  That will show you how much your slider typically travels.
Offline millerza
  • Zach Miller
« Reply #3 on: May 04, 2011, 07:49:17 PM »
lol....that would require me to completely rebuild my bike.  :)
Offline Nikkisixx
« Reply #4 on: May 04, 2011, 08:41:03 PM »
The sliders on my '78 750K traveled about 4 inches - measured using the method I described ^
Others claim as much as 6, your results may vary.
BTW: That is not just chrome on the tubes, but hard chrome (industrial use not for pretty) .
http://www.nmfrc.org/crarchive/Mar02e.cfm
Offline Kong
« Reply #5 on: May 05, 2011, 05:29:58 AM »
Can I ask you something?  I don't know how you plan to remove the chrome, and in particular I don't know how you plan to remove just the chrome for the distance, but those aren't the questions.  The question is this, if you are pretty sure bringing them to the texture you want will cause your seals to fail - which is correct - then why on earth would you want to do it?
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline millerza
  • Zach Miller
« Reply #6 on: May 05, 2011, 03:10:34 PM »
aesthetics only, however I dont "plan" on touching the chrome where it contacts the seal. I will tape off what I dont plan on touching and media blast the rest, then give it a brushed look. And probably PC clear the rough.
If I have a brushed slider(lower) Im thinking I won't like the look of a chrome tube(upper).
« Last Edit: May 05, 2011, 03:12:51 PM by millerza »
Offline lone*X
« Reply #7 on: May 06, 2011, 09:22:19 AM »
Why not just add a set of fork gaiters?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Roach Carver
« Reply #8 on: May 06, 2011, 09:27:31 AM »
Here is my area of question/ concern. If you do it this way you will have a tube with exposed chrome about half way up and totally visible, then a line where you start the dulled/brushed finish. May look weird....
« Reply #9 on: May 06, 2011, 01:31:43 PM »
weird is right! leave it or put gaiters on.  not really safe either.
but if you must, you better get your 'taped' area right, 'cause lets mention the day when you come across that cager and have to brake hard, diving past your taped line, hoping to prevent a wreck, blow a seal and fork oil all over you as you bottom out, and lose handling.... :o
...but dont let me dissuade you  :P
Offline scunny
  • don't call me expert
« Reply #10 on: May 06, 2011, 01:35:06 PM »
+1 for the gaitors
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
