I would really appreciate any help I can get on this. I just replaced my wheel bearings on my '75 CB550 and now I'm reassembling, but the axle nut will NOT fit the correct way. I've taken apart and reassembled a dozen times, each time more slowly and carefully. I'm wondering if I have the wrong parts. When it was together before, the axle nut was facing the wrong way. I may owe a mechanic an apology.
Axle Rod: 7 1/2"
Axle Nut: 1 1/2"
Axle Spacer: 5/8"
This picture basically sums it up. The black line is where the threads start inside the axle nut. I just barely cannot get the threads together to start threading it.
![](http://v3.cache3.c.bigcache.googleapis.com/static.panoramio.com/photos/original/52260875.jpg?redirect_counter=1)
So I thought that I probably didn't have the speedo assembly together correctly. I lined up the little tabs with the notches very carefully. It looks like it could be closer together, but the difference looks pretty obvious if I spin it a little, there's a large gap.
![](http://v1.cache3.c.bigcache.googleapis.com/static.panoramio.com/photos/original/52260862.jpg?redirect_counter=1)
Here are the pieces I have:
![](http://v8.cache5.c.bigcache.googleapis.com/static.panoramio.com/photos/original/52260824.jpg?redirect_counter=1)
![](http://v4.cache3.c.bigcache.googleapis.com/static.panoramio.com/photos/original/52260845.jpg?redirect_counter=1)
![](http://r4.nuq04t04.c.bigcache.googleapis.com/static.panoramio.com/photos/original/52260858.jpg?redirect_counter=1&st=ts)
Any help is greatly appreciated. Thanks in advance.
