Author Topic: Desperatly seeking a head gasket  (Read 2470 times)
Offline bear
  • Leeton in Australia
« on: May 07, 2011, 06:30:45 PM »
I am unable to source a head gasket from my usual supplier and I'm in desperate need of a high-comp. gasket with a 73mm bore.
Any body in Ozz have a suggestion?
Terry, Retro????????
Brian
By the by we have three weeks till the Winton 2+4 meeting and our motor is still spread all over the work shop :-[ :-[ :-[
Tick,Tick,Tick ;D
« Last Edit: May 07, 2011, 06:32:28 PM by bear »
Re: Desperatly seeking a head gasket
« Reply #1 on: May 07, 2011, 09:14:50 PM »
 If you can find a solid copper ot aluminum one of any size, blue it ...fit it over barrel, scribe, and open it up..
« Reply #2 on: May 07, 2011, 10:35:05 PM »
Brian
Tick,Tick,Tick ;D
I have gaskets for a 73mm bore Brian, what type of gasket were you looking for, I will have to go digging because all my stuff is still in boxes but if my memory serves me correctly i think its copper....I will need this replaced , no money involved, if what i have is what you need, i will send you mine with postage and you can do the same in return....Off to check.... ;)
« Reply #3 on: May 07, 2011, 10:48:14 PM »
Sorry Brian, i just checked and i have 2 sets of gaskets but they are 72mm and 71mm. Try Terry mate i am pretty sure he has some 73mm stuff, you could also try Mick7504 He's in Darwin and also has a variety of big bore stuff.....Sorry i couldn't be of more help mate.... ;)
Offline brandEn
« Reply #4 on: May 07, 2011, 11:21:19 PM »
I just went through this fiasco with my 836. I could not find one anywhere. But now Dynoman has them back in stock.
http://www.dynoman.net/bikepages/sohc/gaskets-head.html#1055
« Last Edit: May 07, 2011, 11:24:59 PM by brandEn »
Offline bear
« Reply #5 on: May 08, 2011, 03:57:42 AM »
Thanks mate, I have a 72mm gasket and I will modify to fit if I have to.
I'm trying to avoid it if I can though, because we have had a history of gasket failure with this motor.
Brian
Offline mick7504
« Reply #6 on: May 08, 2011, 04:27:28 AM »
Brian
The biggest copper H/gasket I have is 72mm. (Cometic)
Your names on it mate if it can help you out.
If I was you
I'd be worried about me.
Offline bear
« Reply #7 on: May 08, 2011, 07:09:02 AM »
Brian
Thanks Mick
Much appreciated, will get back to you when we have sorted piston valve clearance.
Brian
Offline kmb69
« Reply #9 on: May 08, 2011, 10:13:56 AM »
 Never hurts to match the holes to the bores......
« Last Edit: May 08, 2011, 10:16:24 AM by 754 »
Offline bear
« Reply #10 on: May 08, 2011, 01:56:42 PM »
There is a 75mm copper on eBay right now and it is in Australia.
http://cgi.ebay.com/HONDA-CB750-K1-F2-BIG-BORE-COPPER-HEAD-GASKET-75mm-nos-/130465700124?pt=AU_Motorcycle_Parts_Accessories&hash=item1e605c991c
Thanks for that but it's actually a 71mm gasket that can be filed back. Trying to avoid that if possible.
Brian
