Author Topic: cb750 exhaust option and a center stand.  (Read 3281 times)
Offline ntm1974
« on: May 07, 2011, 09:38:58 PM »
I've read about 20 threads on this and am still a little confused.
1. Does a 4 into 1 exhaust increase horsepower with larger jets?  If so, how much hp can you gain?  Does this hurt gas mileage?
What exhaust has the best combination of hp gain, ground clearance and can still maintain the ability to use the center stand?
Offline ntm1974
Re: cb750 exhaust option and a center stand.
« Reply #1 on: May 10, 2011, 09:27:39 PM »
Bike is a 76 cb750K
Ok, broke down and got a 4-1 MAC exhaust.  Anyone else running this pipe?  If so: What size jet do I need to get to make it work best with a 4-1 pipe?
Where do you buy jets? (I tried to regular suspects with no luck: partsnmore, bikebandit, oldbikebarn with no luck)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: May 11, 2011, 07:11:09 AM »
I don't think center stands and 4-1's are compatable.
No HP increase usually just weight decrease.
Offline Radam
  • taco racer
« Reply #3 on: May 11, 2011, 07:28:16 AM »
I have that exhaust on my 78 750F (no center stand), but it was already on when I got it so I don't know what the jets are? You can get jets here http://cb750supply.com/
Offline Steve_K
« Reply #4 on: May 11, 2011, 04:38:43 PM »
 I have a Mac 4 into 1 on both my 73 750K and my 76 550K and the centerstands work and function like stock.  You may have to make a stop so the centerstand does not hit the chain.  I am sure the 559 has a Mac, but the 750 exhaust looks like the 550's.
Hope that helps.
Steve
Steve_K
« Reply #5 on: May 11, 2011, 05:13:27 PM »
If you are going to use a good performance pipe then you will need to rejet and there WILL be a small gain in HP as exhaust gas flow has been increased....
Offline GammaFlat
« Reply #6 on: May 11, 2011, 06:06:28 PM »
My K6 had Mac 4-1.  The center stand needed an "L" bracket off of the footpeg to stop the center stand from reaching the chain.  If you don't have one, they're easy to fabricate.
In terms of horsepower and jetting... I don't think there's much difference between the Mac's and stock.  I believe I ended up with stock jetting working fine (after I 86'd the pods and went back to a factory air box).
I've since picked up a new set of HM341's and I'll be running the MAC pipes on my K7.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
« Reply #7 on: May 11, 2011, 06:36:49 PM »
I wouldn't consider a Mac a performance pipe, from what i have seen they offer 2 types of baffle, one for the street, {stock jetting} and a less restrictive baffle that would require some small jetting changes. Some performance pipe manufacturers offer dyno charts to show HP gains.....All the performance 4 into 1 pipes i have used have required jetting changes or they ran lean.....
Offline ntm1974
« Reply #8 on: May 11, 2011, 07:51:54 PM »
Thanks for the advice.  My thinking on getting a 4-1 is to increase ground clearance and to allow me to use a center stand.  If I got a performance increase, it would just be an added bonus.  I figured that I should change the jets if needed considering that I have to take the carbs off to clean them anyway.
Thanks again
« Reply #9 on: May 11, 2011, 09:56:20 PM »
Just to let you know, most of the pipes i have used did not allow the use of a centre stand, i always take them off anyway because they are bloody heavy and scrape on the road.....
