Author Topic: Earth 400/4  (Read 577 times)
Offline patlac
Earth 400/4
« on: May 10, 2011, 04:58:56 AM »
  Hi fellows my 400/4 seems to be going ok now Thanks for help and  suggestions. What I would like to do now is bring all my earth connections to one point. A friend who had a lot of Elec. faults on his CB750 done this and cured his problems He brought all earth wires to a junction box under the saddle and connected the box to the Batt earth point on the Engine, Where is the main earth point on the 400 or is there one.
Offline kirkn
Re: Earth 400/4
« Reply #1 on: May 10, 2011, 07:49:18 AM »
In general, all the frame is ground (earth).  Battery (-) usually connects to a frame/engine mount bolt thus making the entire engine and frame into ground.  Any metal component bolted up to either frame or to engine thus also becomes grounded unless painted/rubber mounted/corrosion'd.  Go from there.
Offline patlac
Re: Earth 400/4
« Reply #2 on: May 10, 2011, 12:06:04 PM »
Thanks for reply I thought that there was a couple of points the Earth wires were brought to on the Frame
Offline kirkn
Re: Earth 400/4
« Reply #3 on: May 10, 2011, 04:21:44 PM »
There may very well be.  I don't have one to know specifically.  I'm just talkin' in general for any motorcycle...
Offline patlac
Re: Earth 400/4
« Reply #4 on: May 11, 2011, 02:56:37 PM »
Thanks Again I will have a good luck around when I get Time
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: Earth 400/4
« Reply #5 on: May 13, 2011, 10:09:34 AM »
May have been better to post in the Tech Section.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
