Author Topic: 750F vs 750K Gasket kit  (Read 915 times)
Offline b82ta
« on: May 14, 2011, 06:46:52 AM »
Hello all,
I'm finally getting back to my head rebuild project on my 750F after spending 4 months overseas.  I noticed this morning that I have a top end gasket set for a 750k I think the package says '74 on it?  I didn't notice it before I left, and my research on here shows the head gaskets are different, but does anyone know if I can order a new head gasket and reuse the rest of the kit?
Thanks!
Offline b82ta
Re: 750F vs 750K Gasket kit
« Reply #1 on: May 14, 2011, 06:51:43 AM »
In case this helps, its a Vesrah kit VG556 kit. It also says that it covers up to '73
Offline wrenchmuch
« Reply #2 on: May 14, 2011, 01:11:58 PM »
 The sites I usually look for parts on (partsnmore / cyclex ) only list the one kit for sohc 750 fours . I can't think of any reason your kit won't work . O-rings differ on some models ( cam tower o-rings are smaller 69-72 ).
CB750K1
CB750K4
Offline Mandic
« Reply #3 on: May 14, 2011, 04:50:40 PM »
What year 750F?  The headgaskets are the same.  The difference only really lies in a few of the o-rings.  Mind you the difference can be a fairly big one and no one seems to make the replacement proper o-rings.  But those rings are at the base gasket, not head and only on the 77-78F.
77 CB750F - Cafe/Daily Rider
Offline b82ta
« Reply #4 on: May 15, 2011, 08:06:12 AM »
'78 750F.  So as long as I watch the o-rings and just check everything against what's coming out I should be alright?  There was another post about the '77-78F's having a different head gasket so I'll check that one against what's on the bike and order a new one if I have to.  As long as everything else should work, I don't mind having to source a couple different parts.
Offline 78 k550
« Reply #5 on: May 15, 2011, 08:41:54 AM »
I have a 77F rebuild kit if you want to compare.  HaHa.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Mandic
« Reply #6 on: May 17, 2011, 01:29:44 PM »
I've gone through my 77 750F2 motor a couple times in the past few months(stupid reasons) but the head gaskets are just standard ones.  WEll standard the first time, then 2 different 836 ones, but no one ever asked "is the bike an F or K?" when it came to head gaskets.
