Author Topic: Throttle Conversion  (Read 976 times)
Offline Spades
  • '78 Honda CB750 / '79 CB 650
Throttle Conversion
« on: May 14, 2011, 09:43:06 AM »
I am not sure how much of my bike is stock but I think the throttle is. It is currently clamped to the bars using the engine kill switch which also contains the starter button. I want to get rid of that entire assembly as the kill switch is dead and I found one I want to change to.  My question is will this throttle tube work on our bikes?
http://www.motionpro.com/motorcycle/partno/01-0058/
I have also done some searching and can't seem to find the answer. I remember reading somewhere that I can swap for an '00 GSXR master cylinder and lever .. but other than that what other option do I have to get rid of that large reservoir on the bars?
'78 CB750K Bobber
'79 CB650 Cafe
Re: Throttle Conversion
« Reply #1 on: May 14, 2011, 09:54:11 AM »
That should work fine. You'll probably have to ask Motion Pro if the stock cables fit it, or if they make a pair that do fit it, as the little cable pull holes and threads might be different from the Honda version.
