Author Topic: 15a fuse for main???  (Read 794 times)
Offline sky56
  • would you like to see my
  • Chgo winters can suck but great time to wrench
« on: May 14, 2011, 12:57:08 PM »
Hey guys I scored some sweet 12 ga wire all blk and all red and at one end of each is a encased 15a blade type mini fuse. Can I use this as my main between battery and ignition switch? Thanks guys or can the fuse be replaced with another fuse say a 20-30a one? The holder doesn't specify anything. Thanks
Many honda bikes and a lifted 75 Chevy K5
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
Re: 15a fuse for main???
« Reply #1 on: May 14, 2011, 01:17:28 PM »
If you're talking about the type that can be purchased at the auto parts store, I have those for my bike. I think the advertise them as "waterproof.".  I got them because the PO had switched to blade fuses - but just exposed spade terminals with nothing to protect it from the elements.
 I know one of the ones I got was rated for higher fuses. It was bulkier than the others. I used that for the largest (15A).
Maybe there is a number on yours you could look up to check the manufacturers rating on their site???
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Bodi
« Reply #2 on: May 14, 2011, 03:06:27 PM »
12ga is good for 20A as a rule. Having more than a 15A main is a bit risky, the harness wires can overheat severely with 20A should you have some sort of failure that doesn't quite blow the fuse.
