Author Topic: electrical help please..  (Read 527 times)
staplerplease
« on: May 15, 2011, 01:11:55 PM »
my 1980 cb650 custom keeps melting or blowing the main fuse doesn't happen all the time, the whole charging system has been replaced,i even replaced the wiring on the charging side, only thing i can can figure is the batt won't take a charge passed 12.2 volts when it should be around 12.6..could that be overloaing the wiring causing it to back up and blow the fuse..help..i'm lost..
Offline c(b)hris
Re: electrical help please..
« Reply #1 on: May 15, 2011, 01:18:22 PM »
Have you changed anything since the last time it worked?  I just had the same problem, but I was putting things together in the headlight bucket.  I went through slowly and finally found that I plugged one connector into the wrong wire.  Maybe something is getting shifted around and grounding out randomly?  Is your ground tight?
75 CB550
74 CB750
