Author Topic: Transmission Troubles - Second gear stutters and kicks  (Read 3372 times)
Offline Stevenarrow
« on: May 15, 2011, 01:46:40 PM »
Hello,
I am having issues with my cb750 K5. When accelerating in 2nd gear the bike stutters, kicks and loses power. The issue only happens in 2nd gear between 30-40 mph. All other gears and speed are fine: clutch, timing, and carbs are fine.
Working with my mechanic, he assures me, it is the gear selector forks. My mechanic is great and loves to educate; i was hoping that someone with specific knowledge of this bike / issue can confirm his suspicions. Reading more on this issue in the forums; it seems not uncommon for his assessment to be true.
If this is the issue, then splitting the case is the only way to fix it. i could do this with my mechanic's help but it will cost me time: any advice.
thanks for looking.
Offline 750essess
  • Orleans Cycle Repair & Resto
Re: Transmission Troubles - Second gear stutters and kicks
« Reply #1 on: May 17, 2011, 07:08:49 AM »
your mechanic is correct. just repaired one like this the shift fork will be bent and most likely the gear dogs will be worn for that gear. splitting the case is the only way to repair.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline Stevenarrow
« Reply #2 on: May 17, 2011, 10:42:32 AM »
Thanks for the reply -- it's good to hear from people who have experience with the machine in question.
Should i then be prepared to replace both the selector fork and the gear itself for the repair? Are there any other parts i should have on hand before i pull the engine?
« Reply #3 on: May 17, 2011, 11:29:30 AM »
CB750s would damage 2nd gear usually from abuse by the owner. The symptom is usually that it jumps out of second gear into a false neutral. Especially when accelerating.  The engine would then over rev, and the frightened bunny would try to cram it into gear again, furthering the damage.
The 1st to 2nd shift is the one where jack rabbits are trying to shift fast and really put their foot into the process, bending the shift fork and rounding off the edges of the engagement dogs on the respective gears.
But your symptom description is puzzling. Does it actually lose power, or does it jump out of gear?
« Last Edit: May 17, 2011, 11:31:37 AM by MCRider »
Offline Stevenarrow
« Reply #4 on: May 17, 2011, 12:37:40 PM »
Sorry, I don't mean that it loses power from lack of combustion or anything -- I mean, loses power from lack of gear contact. The symptom is only brief and happens when under acceleration in 2nd. It does not jump out of gear.
« Reply #5 on: May 17, 2011, 12:52:38 PM »
OK that's probably it. I've never heard of one that didn't jump out of gear and STAY out of gear. "Brief" as you say. Not much else it could be though.
Offline Stevenarrow
« Reply #6 on: May 17, 2011, 01:23:32 PM »
Thanks,
I guess my next step is to track down the parts.
« Reply #7 on: May 17, 2011, 01:31:02 PM »
Thanks,
Potentially more bad news. I think the center fork (the one you need I think) is discontinued, though you may find a dealer with NOS. The gear is also, but Yamiya has replicas for $450+ I think. They may have repro forks now too.
Good used is best bet, but a gamble.
Offline Stevenarrow
« Reply #8 on: May 17, 2011, 05:11:02 PM »
thanks for the heads-up.
Is there any good reference material as to which parts are interchangeable with other K model 750's...?
..will a K4 or later model fork and gear fit into my transmission?
« Reply #9 on: May 17, 2011, 06:33:54 PM »
All the Ks, at least up to 77/78, K7/K8 are interchangeable. The late ones may be also. I would bet, I just don't know. Same for the Fs, I think.
Offline Stevenarrow
« Reply #10 on: May 17, 2011, 06:45:18 PM »
good news. there seem to be plenty to choose from on ebay.
« Reply #11 on: May 17, 2011, 07:03:33 PM »
I see Yamiya now has the shift fork as well... for $262. Anything less than that is bonus.
http://www.yamiya750.com/index.php?main_page=index&cPath=21_64
Assuming you didn't know, yamiya is famous for finding sources to reproduce unavailable parts. Often the prices are pretty high.
You may find a friendly dealer who can do a parts search and find a leftover gear and fork at a dealer or warehouse. The original Honda OEM prices were about $130 and $60 IIRC.
« Last Edit: May 17, 2011, 07:11:54 PM by MCRider »
Offline Stevenarrow
« Reply #12 on: May 19, 2011, 07:51:18 AM »
thanks for the link. But i think i have to check the used market before committing to the higher prices.
...I just got a complete transmission from another K5 with 11000 miles for $40. I'll check out the condition and go from there.
Thanks again for the help.
« Reply #13 on: May 19, 2011, 07:58:45 AM »
Wow! That's great, should work. Damage to the fork and gear are usually obvious to the naked eye.
