Author Topic: So my chain came undone as I was riding...now no start?  (Read 6824 times)
Offline Dave-and-his-550
  • I know the pieces fit...
Luckily it did not bind with the rear tire or I'm sure I would have been grounded. I'm REALLY glad that did not happen. I trailored the bike home and forced off the sprocket cover. The chain was stuck inside against it. The master link on the chain came out. I don't understand why because I was certain to put the retaining clip on properly as I knew how important it was. I guess maybe if the chain was way to loose? Or not well enough oiled? Faulty clip? Evil rock? I guess its impossible to really know.
Anyway, there was some damage to the aluminum on the motor, and on the sprocket cover. I guess I'm wondering if there are any foreseeable issues with reusing the sprocket cover as is? Here are some lovely pictures of the damage:
« Last Edit: June 08, 2011, 02:56:44 PM by Dave-and-his-550 »
Re: So my chain came undone as I was riding...
« Reply #1 on: May 15, 2011, 08:58:37 PM »
Really have to double check those clips that they are tight and fit into the groove nicely on the pin. Also mount so the open end is away or pointed towards the back of the bike. Different chains require different master links so make sure they are compatible. Very glad your ordeal turned out as well as it did  :)
« Reply #2 on: May 16, 2011, 02:02:19 AM »
if the link was old and had been on and off several times the clip can get soggy,make double sure the grooves it sits in is clean,also the wrong clip may have been used from a different brand?i always order another master link with new chains.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: May 16, 2011, 03:14:29 AM »
This applies if you are viewing the clip on the upper run. A better way of describing the orientation of the clip might be that the closed end of the "U" should face the direction of chain travel.
« Reply #4 on: May 16, 2011, 04:11:21 AM »
Thanks Bob for a better explanation-after I thought that over I knew I muffed it depending on which part of the chain it was on,top or bottom.  8)
« Reply #5 on: May 16, 2011, 02:00:56 PM »
Thanks for the replies and the confirmation on how it is installed. I know I had it right. And the chain was brand new! Including the ML, and clip. Had no more than 150 miles ridden...Hmm, I think I just forgot to check the tightness of it before I rode off with it. Or maybe it wasn't well oiled. Maybe the clip was just fractured or not all the way on...It was my first ride of the season, I guess I was a little excited. Should have checked those things.
I did order a replacement 530 ML, I'm going to put it back on and ride it around. Oil the chain real good, check for proper tightness, and for now on I think I would be a little paranoid NOT to check that MC every time before I ride.
So I'm going with the assumption the cracks in the case and chain guide on the sprocket cover are no big worry?
Offline lone*X
« Reply #6 on: May 16, 2011, 02:59:30 PM »
The case is a cosmetic and safety item to protect your ankle.  It doesn't seal anything.  If you can live with its appearance and it is sound in structure put it back on and ride.  If the damage to the cases was all external and didn't break the integrity of the lower end (no oil leaks) I would say you are lucky and ride it.  One question, did your 550 have the steel chain guide installed around the front sprocket?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
KingCustomCycles.com
« Reply #7 on: May 16, 2011, 04:32:34 PM »
About that clip facing foreward comment......it faces forward and rearward depending on its location on top or bottom as it rotates.
« Reply #8 on: May 16, 2011, 04:52:50 PM »
If referring to the chain guide that mounts to the inner of the sprocket cover then yes. Actually, I had to take that out and put another one on from a spare sprocket cover. Because it would not mount up due to it being bent. No oil leaks luckily. Oddly though, my bike's neutral light will not come on all of a sudden  ??? maybe a bulb popped coincidentally at the same time.
I got the chain back on and its ready to ride, gonna go take it for a spin now around the block, double check the chain etc,
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #9 on: May 16, 2011, 05:09:05 PM »
Chain probably smacked the neutral switch when it snapped.  I doubt it's the bulb, but ya never know.
« Reply #10 on: May 16, 2011, 06:00:08 PM »
This probably happened. I was going to ask if there was something in there related to this dilemma. Anyway, out I go for a ride (Decided to go eat Chinese first)
« Last Edit: May 16, 2011, 06:24:41 PM by Dave-and-his-550 »
« Reply #11 on: May 16, 2011, 06:25:41 PM »
WHOOPS, I guess that little neutral light dilemma is more of a dilemma then I thought. The electric starter wont work. I guess a logical safety precaution on Honda's part. But now I gotta figure out how to get it working again. Any advice where to start?
So the culprit might be #15, or so in this picture? "neutral switch stator" ?
« Reply #12 on: May 16, 2011, 11:32:18 PM »
15 and or 16 and make sure the wire is clicked into its position,dont distort the link clip when fitting it.
« Last Edit: May 16, 2011, 11:34:08 PM by dave500 »
« Reply #13 on: May 17, 2011, 03:27:33 AM »
...I've seen where guys have safety wired that little puppy!
Offline singedebile
« Reply #14 on: May 19, 2011, 12:09:45 PM »
this is a really nice little simple video! not only does it show the direction it should be facing (i believe you can see the rear sprocket to the right), but it shows in a nice fluid way how to pop off then back on the clip! I am about to do this and feel a whole lot better about it!
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
« Reply #15 on: May 19, 2011, 12:46:44 PM »
make sure the screwdriver has an edge as wide as the open end of the clip and is ground nice and square,a rounded of one will cause grief,the one i used here could have been a little wider.
Offline Greggo
  • Somebody's
« Reply #16 on: May 19, 2011, 05:51:41 PM »
I just put on a new Tsubaki that required me to press the master link plate onto the pins.  I'd never come across that, but my neighbor let me borrow his breaker kit.
Offline Quorthon
  • Pace till death
« Reply #17 on: May 19, 2011, 06:57:49 PM »
My master link plate had to be popped on also.  I was able to get it with channel locks/ vice grips, one or the other.
1972 cb500/4
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« Reply #18 on: May 19, 2011, 07:08:36 PM »
find the wire to the nuetral switch, in the harness connector from the stator area which i believe is the light green/red out of the starter solenoid, and ground it to the frame, if the nuetral light comes on, you damaged the wire to the switch itself
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline skamagedon
« Reply #19 on: May 19, 2011, 07:10:19 PM »
BTW, my chain cut that same groove to the left of the sprocket on that "plug" thingy
« Reply #20 on: May 20, 2011, 12:17:12 AM »
That is common when oring/xring chains are put on the Cb550.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #21 on: May 20, 2011, 05:03:09 AM »
Yes we used to wire them on the 60/70's race bikes. Thin wire round the back/inside of chain link and twist the wire on the outer side by the waisted part of the link, it should clear the sprockets ok and be sure to bend the twisted wire in the direction of travel again so it doesn't snag.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline Fritz
« Reply #22 on: May 20, 2011, 11:09:46 AM »
Using a standard non-O-X-W-any-ring chain will prevent this - not so cosmetic - damage.
I'd never use a clip-on master link on my chain. Rivet it or have it riveted or leave it
my 2ยข
1976 CB550F
bollingball
« Reply #23 on: May 20, 2011, 11:31:18 AM »
I have not used any thing but clip on master links since 1967. Never has one failed me .It is not the link it is the installer. Pay attention to details Anyone who has spent much time reading this site knows you cannot put these fat chains in these tight spaces.
Offline skamagedon
« Reply #24 on: May 20, 2011, 11:13:35 PM »
what is that plug lookin thing anyway? not to thread jack but .....
