Let's make sure you are talking about the cylinder head bolts. There are about 18 bolts for the valve cover that are torqued roughly hand tight.
The cylinder head bolt torques seem to range from 14-16 ft-lb. I've seen that range given a few times, so I go by the upper end of it usually. If you have done any performance work (466 kit, higher compression pistons, etc.) then you can even go up from there. Kaz Yoshimura recommended 18 ft-lbs for his race bikes without mention of replacing the stock studs. FYI, I have a 466 kitted engine with bored out carbs that I have torqued to 16 ft-lbs and do not have any leaks or issues (that is a very fast engine too!).
Camelman
