Author Topic: Custom led tail lights  (Read 7953 times)
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« on: May 16, 2011, 02:07:35 PM »
again with the new tech on the old bike....I used 10mm red leds in series of 5 each with a 60 ohm resistor. if you want to use more leds go here for the resistor value
http://led.linear1.org/led.wiz
the white wood was the bottom of a drawer. It has a run and stop arrays. Soon I will do my winkers.
 Some more pics are here.....   http://www.flickr.com/photos/57177301@N08/?saved=1
Hot glue is your friend, stops rattles, shields wires.
« Last Edit: May 16, 2011, 02:09:27 PM by skamagedon »
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Offline Telorand
  • Right-handed Turner Extraordinaire
  • Huzzah!
Re: Custom led tail lights
« Reply #1 on: May 20, 2011, 08:17:15 AM »
How's the brightness on that setup with the lens?  Comparable?  I was considering 10mm whites for a LED Headlight build (for the low beam part, anyway).
1974 Honda CB350F1
Offline skamagedon
« Reply #2 on: May 20, 2011, 08:53:48 AM »
i would use 15-20 for a headlight. its slightly dimmer than stock bulbs. i may ad 10 more to the running array
Offline skamagedon
« Reply #3 on: May 29, 2011, 11:45:37 PM »
so i added 10 to the stop array instead.
Offline Telorand
  • Huzzah!
« Reply #4 on: June 08, 2011, 08:22:32 AM »
How's the brightness now?
1974 Honda CB350F1
Offline skamagedon
« Reply #5 on: June 08, 2011, 05:26:46 PM »
bright enough for a sunny day. and changes shape well
Offline Telorand
  • Huzzah!
« Reply #6 on: June 09, 2011, 10:40:47 AM »
Good to know.  I think I might give this one a try in short while. :)  Thanks for the project report!
1974 Honda CB350F1
Offline skamagedon
« Reply #7 on: June 23, 2011, 10:43:04 PM »
so i made a new running array design. enjoy
Offline Telorand
  • Huzzah!
« Reply #8 on: August 17, 2011, 08:18:07 AM »
That's awesome!  I like that idea.  I forgot to ask, did you get or make your lens clear?
1974 Honda CB350F1
Offline skamagedon
« Reply #9 on: August 17, 2011, 08:20:28 AM »
i left it stock lens. it shows well
Offline skamagedon
« Reply #10 on: April 07, 2013, 12:25:59 AM »
new blinks, el strip and kz cafe tail
IMAG0819 by Skamagedon1, on Flickr
IMAG0129 by Skamagedon1, on Flickr
IMAG0114 by Skamagedon1, on Flickr
IMAG0118 by Skamagedon1, on Flickr
Offline heyitsrama
« Reply #11 on: April 07, 2013, 11:41:45 PM »
If you have an AVR programmer (USBminiISP) you could build one of these
http://hackaday.com/2012/04/16/motorcycle-lighting-upgrade-ensures-other-drivers-know-youre-there/
I wonder how much it would make a difference as far as visibility goes.
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
