Author Topic: Finally an Introduction  (Read 647 times)
Offline SAEmiles
« on: May 16, 2011, 04:58:46 PM »
My name is Miles. I've posted a few times, but mostly I've just been lurking trying to absorb information.
As for the bike. It is a 1977 Cb550F.  I bought it from a member on here in October 2010 for $650 in non-running condition. The first thing I did was take the carbs apart and clean them. I took a toothbrush to the bowls and boiled the jets and small parts in a lemon juice solution. After that I put everything back together with new plugs and a new fuel filter. Unsurprisingly the bike was not ready to ride yet.
The previous owner mentioned the bike had a dyna S ignition system that had not been properly timed yet. So I borrowed a timing light and set the timing. On top of everything, the wiring harness had been hacked up at some point and was in questionable condition. I got the main harness sorted out and moved on to properly connecting the running, brake and tail lights.
After getting a title issue sorted out somewhere in the middle, and getting a flat tire the day after I got it running, here it is.
« Last Edit: May 16, 2011, 05:49:43 PM by SAEmiles »
Offline bender01
Re: Finally an Introduction
« Reply #1 on: May 18, 2011, 07:23:16 PM »
Welcome. Where are you located.. I like the 550s.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline SAEmiles
« Reply #2 on: May 18, 2011, 07:38:23 PM »
I should have mentioned that. I'm located in Orlando, Florida. I bought the bike from a guy in vero beach.
