Author Topic: Fork boot popped off...  (Read 2757 times)
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« on: April 19, 2006, 07:04:40 PM »
...the bottom popped off one of my fork boots.  I've been trying on & off for two nights to get it back on with no luck.  Is there a method to this madness that I'm missing?  Help.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline Bob Wessner
  • "Carbs Suck!"
Re: Fork boot popped off...
« Reply #1 on: April 19, 2006, 07:33:04 PM »
Are these the rubber accordion types? If so, as I recall on my 750 (had to replace mine) there's a groove around the fork at the bottom and a corresponding lip on the lower inside of the boot. It slips into the groove. Hope I got this right, it was over a year ago.
Offline csendker
« Reply #2 on: April 19, 2006, 08:19:14 PM »
Yes, accordion type.  There's a groove on the fork and a corresponding lip inside the boot.  There's also a notch in the fork and a notch in lip inside the boot, why, I'm not sure.  For the life of me I can't get the boot 'expanded' enough to slip over the fork.
Offline Bill Vaughan
« Reply #3 on: April 19, 2006, 09:15:01 PM »
Just a guess, but could those be aftermarket boots?  The bottom collar (below the accordian section) looks to be much longer than that of the stock Honda boot.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: April 20, 2006, 01:45:56 AM »
I' withl Bill on the aftermarket suspicion. The lower bit of the boot looks too slender as well, which is why you can't stretch it over the fork body. Where did you get the boots?
Offline dusterdude
« Reply #5 on: April 20, 2006, 06:15:52 AM »
as far as stretching it over the fork,heat the rubber with a blow dryer that should make it pliable enough to fit it over the fork.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline csendker
« Reply #6 on: April 20, 2006, 06:22:12 AM »
They came with the forks.  I would concur with the aftermarket thought as they look to be in pretty good shape for supposedly being 36 years old.  It did occur to me that the one that's on is really stretched out.  And they are also a lot shineyer than what's on my 550.  No little holes either (Bob: thanks for the tip, I checked my 550 and one had the holes facing forward...)  In my search for an answer, I found an older thread about using aftermarket truck boots from JC Whitney on a 550.  I looked them up, but they only seem to have red nowadays.  I'll keep trying (good idea about the heat DD) while I begin a search for a new set.
« Reply #7 on: April 20, 2006, 01:04:29 PM »
Okay, here is how I would get them back on.
Stretch and pull down the boot on the least accessible side and hold it there with ones hand.  With a blunted right angle scribe slide the tip up under the fork boot between it and the fork lower.  You can now pull the rubber out and away from the fork and slide or walk the boot over and around the fork lower top edge.
Some silicone spary might help with the scriber.  But, it won't help your hand grip, so strategic placement is recommended.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: April 20, 2006, 01:35:56 PM »
csendker,
If you are interested in returning them to stock (and they will be a lot easier to get on), and they have them for the 550, they shouldn't be too expensive. The pair for my 750 weren't. Just a thought.
Offline csendker
« Reply #9 on: April 20, 2006, 02:26:54 PM »
Alas, this is for my 175 project.  However, lots of the good ideas here, I think I'll try later tonight when I get my chores done.  I have found some new ones, so if all else fails...
Offline csendker
« Reply #10 on: April 26, 2006, 08:03:49 PM »
Well I finally got back to this last night.  I used a combination of a hair dryer (thanks DD) and lever technique (thanks TT).  I decided to forgo the silicon at first.  Never needed the second try, as it went back on with very little difficulty.  Thanks all.
