Author Topic: need help with stripped carb screw  (Read 1217 times)
Offline slowjo
« on: May 20, 2011, 02:25:06 PM »
One of the vacuum screws on my 1972 CB750 just stripped. What are my options? I have searched for posts on what other people have done but I'm still looking for some options.
Offline mrrch
Re: need help with stripped carb screw
« Reply #1 on: May 20, 2011, 05:33:50 PM »
The head stripped or did the threads strip?
my build
Offline slowjo
« Reply #2 on: May 20, 2011, 05:48:41 PM »
The threads did. When I tightend the screw it just kept spinning and would not tighten up.
Offline magconpres
« Reply #3 on: May 20, 2011, 06:39:12 PM »
Maybe put in a heli-coil?
Sent from my PC36100 using Tapatalk
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
Offline jimbojangles
« Reply #4 on: May 21, 2011, 05:54:15 PM »
Z1 sells a quick connect adapter that you can seal in the port with some liquid gasket or something similar. That's what I did and havent had a problem since.
1974 CB350F
2013 VFR1200F
Offline slowjo
« Reply #5 on: May 21, 2011, 06:17:44 PM »
Thanks for the idea. I think I did see this in a old post. So I jumped the gun yesterday and ordered 4 5mm adaptors. After thinking about it at work I should have ordered one 6mm adaptor for a tighter seal/fit. A friend of mine has a tap and die set. So after work I placed another order for the one fitting. Thanks again.
Offline nayto550
« Reply #6 on: May 21, 2011, 07:23:14 PM »
This happened to a Suzuki GS500 I used to own.  I got an oversize screw, drilled and tapped the hole.  IMHO, this is the way to go, don't have to deal with helicoils or any sort of sealant compounds.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: May 21, 2011, 09:20:55 PM »
Happened to me. I just got a 5mm tap and ran it through once. Worked like a charm.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
