Author Topic: How to Remove the Steering Cone (race) from the Steering Stem  (Read 2228 times)
Offline craigermags
Hi There, I have a need to replace the steering cone (race), dust seal and washer on my 1971 BC750.
How do you remove this. It looks pressed on but I am not sure.
Can any of the experts out there help with the correct method. thanks  Craig
Offline CycleRanger
  • No comment about being an
Re: How to Remove the Steering Cone (race) from the Steering Stem
« Reply #1 on: May 20, 2011, 05:48:07 PM »
Search the forums, there's several threads about this.
The preferred method seems to be score the race with a Dremel tool or a file and give it a careful whack with a chisel to break the ring.
Oh, this is for the stem race.
« Last Edit: May 21, 2011, 11:12:12 AM by CycleRanger »
Offline wohali
  • What, me worry?
  • Don Pardo, tell 'em what they've won!
« Reply #2 on: May 21, 2011, 10:20:24 AM »
On my '78 CB750, I was able to drive the upper one out with a long piece of threaded rod and a sledgehammer. On the bottom race I think I got most of the way there, destroyed a few pieces of threaded rod in the process, then did the nick-and-remove technique.
Offline Lamp
« Reply #3 on: May 21, 2011, 11:55:17 AM »
When I replaced the steering stem bearings on my F-model front end, I had to heat a small area of the inner race on the steering stem until it was red hot. Then I beat that spot with the ball end of a ball pen hammer to stretch the race out. Then I just garbed the race with some large pliers and worked it off.
1972 CB750K, with lots of F-model parts... SOLD
« Reply #4 on: May 21, 2011, 10:22:09 PM »
 If you are near my shop I have the proper tool.. takes a few minute, leaves no marks, and rubber and washer is reuseable.
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« Reply #5 on: May 22, 2011, 08:28:02 AM »
read my build thread...its in there.  Reply #24...
Use a "blind hole puller"...takes 5 mins...
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
