Hey all,
I put a new cycle x 4-2-1 exhaust on today (sounds awesome btw
), reset the ignition timing, and went to sync the carbs...
So the carbs are now all synced, but the needle is reading at 4 "inches"(?) on the vacuum side - in the red area which reads "late valve timing or leak at intake manifold or heat riser"
I can't find any leaks, so I'm assuming my valve timing is a little retarded?
Does that mean my camshaft is installed wrong, or I need to replace it?
It runs really well so I'm kind of stumped at this point.
Thanks for the help guys!
- Adam
