Author Topic: 550 front brakes  (Read 1288 times)
colmbarry
550 front brakes
« on: April 20, 2006, 06:09:01 AM »
On removing stuck pad & cylinder from the front caliper.  I have read many posts here suggesting the use of compressed air or a grease gun to pop out these parts.  My question is, how do you hook up for air or grease ?  If using the grease gun method, what size zerk fitting do you use ?  Is it a standard size, readily available ?   If using compressed air, what kind of fitting do you use ?  What size is it ? Is it easily available ? Is it like a shrader valve where you would use the same airhose end that you use to inflate a tire.
Thanks.
Colm
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: 550 front brakes
« Reply #1 on: April 20, 2006, 06:57:16 AM »
I used a small grease gun.  If I recall correctly, you take the female zerk fitting OFF the end of the gun.  The corresponding thread, while not exact, will fit the brake hose fitting just enough to grab on. Then start pumping grease into the caliper to force the piston & pad out (with the bleeder closed).
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline csendker
« Reply #2 on: April 20, 2006, 06:58:18 AM »
And if you use air, be careful as the whole mess can blast out of the caliper like a bullet.
wildbill903
« Reply #3 on: April 20, 2006, 07:21:49 AM »
i just popped mine back on the bike and pumped brake fluid through it.  Put a catch can under so you dont spill brake fluid all over, that can cause quite a mess.
Offline Jonesy
  • Shop Rat
« Reply #4 on: April 20, 2006, 08:45:11 AM »
It will have a bang like a rifle, too- wear ear protection! Compressed air is not my first choice for this task... kinda dangerous.
Offline Paul
« Reply #5 on: April 20, 2006, 09:19:19 AM »
To the best of my knowlage....
The port where the brake line goes in is 1/8" BSP thread.
I think a 1/8" NPT will go in enough to bite (but mind the threads)
If you can get at the ring / groove area around the cylinder/piston, try to get all the corroded alluminium (aluminum) out as this acts to prevent the piston from comming out.
I find if you put the caliper into something like a ziplock bag and / or a box/tin to keep everything from spraying everywhere....they are a #$%* to move.
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
