Author Topic: Replacing a Petcock  (Read 1619 times)
Offline JoshuaJames
Replacing a Petcock
« on: May 23, 2011, 12:34:04 PM »
Hi,
I have a gs 450 tank that I will be mounting on my CB550F. The petcock is a vacuum one, and the carbs I have are not. Also, the current petcock hangs a bit low right now. I would like some more clearance between my carbs and the petcock. So...... I was thinking of buying an adapter plate from here:
http://www.partsnmore.com/parts/suzuki/gs450/?filters%5Bprice%5D=50
And then buying a new, non vacuum, petcock.
Has anyone done this before? are there any recommendations or suggestions? Any feedback will be appreciated.
thanks
Offline JohnDRitter
Re: Replacing a Petcock
« Reply #1 on: June 11, 2013, 09:18:12 PM »
thinking of doing the same here, how did everything work out? or did it at all?
Its a little motor and it likes having the tits revved off it.
Offline JoshuaJames
« Reply #2 on: June 12, 2013, 06:14:01 AM »
worked like a charm! no issues so far. you may want to upgrade the gasket, as the one that comes with the petcock I purchased is kind of cheap, but other than that, perfect!
