Author Topic: 81 cb650...one mismatched carb???  (Read 1162 times)
Offline nuzzi
« on: May 25, 2011, 09:48:56 AM »
i just started to dig into this bike i picked up recently and noticed the second carb in (from your left leg) has a different bottom cover, it has some kind of adjustment screw on it or something, i didnt really look to far into it as i had little time, is this normal or do i need a new carb now? the tops look the same.
Offline Bankerdanny
  • Endeavor to persevere
Re: 81 cb650...one mismatched carb???
« Reply #1 on: May 25, 2011, 09:56:39 AM »
I don't know about 650's, but the #2 carb on my 550 is slightly different than the rest in that the slide does not include the adjustment screw on the top for synching that the other 3 carbs have. Other than that it is physically the same as the rest.
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #2 on: May 25, 2011, 10:05:03 AM »
 Given that your bike is an '81, you should have CV (Constant Velocity) carbs, which are somewhat different from the mechanical carbs most of us have.  As compared to the carbs on my '80 CB650, the #2 carb is the baseline for the others, and mine has an accelerator pump on the bottom of the #2.
Your first line of defense is your repair manual(s), followed by the search function here.  There's some good info in the FAQs and How-Tos, too, though info on our 650s is sometimes limited.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline OrganDonor
    • My other hobby...
« Reply #3 on: May 25, 2011, 01:26:09 PM »
The second carb should also have an accelerator pump which feeds all carbs from the #2 bowl.  The accelerator pump shows up as an extra cover with 3 screws on the inside of that carb and to the rear.
77 CB500K
80 CB650 Custom
76 CB750K
Offline Frankenkit
  • Industrial Strength
« Reply #4 on: May 25, 2011, 01:50:13 PM »
I thought only the 79-80 #2 carbs had the accelerator pump?
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline cb650
« Reply #5 on: May 26, 2011, 05:56:43 AM »
All the 650's have a accel pump.
Offline nuzzi
« Reply #6 on: May 26, 2011, 08:11:42 AM »
thats what i assumed, thanks!
