Author Topic: Complete Front end swap  (Read 1111 times)
76 SOHC
« on: May 26, 2011, 08:17:34 AM »
I just picked up a complete front end off a CBR600 for 250$. I wanted a cleaner set of controls and a little beefier tire on the front to match the back.   I checked on the ALL Balls Racing site and it will  go on without any issues...  My question is I want to keep the spoke wheel.  The CBR front was I believe 16 the stock 750 wheel is 19.  Any ideas?  I know we have a lot of people that swapped there forks?
Thanks for reading and I appreciate the help.
Offline Roach
Re: Complete Front end swap
« Reply #1 on: May 26, 2011, 08:24:06 AM »
you will need to buy a 19" rim if that is the size you want or if you have a 18" rear i would run a 18" front.
then it is a matter of a hub you will need to buy a harley davidson front hub not sure what year......
as well as spokes and learn to build a wheel..
hope that helps
1978 CB550K Cafe Racer
76 SOHC
« Reply #2 on: May 26, 2011, 08:49:55 AM »
Can I keep my 750 hub and just respoke it to a wider rim?
Offline hyde7278
« Reply #3 on: May 26, 2011, 09:34:07 AM »
No diffrent size axle. Thats why you need a HD hub with a 3/4" axle
78 CB550 (FOR PARTS)
76 CB550F
Offline johnrdupree
« Reply #4 on: May 26, 2011, 10:01:39 AM »
What year is the CBR front end?  The All Balls site only compares bearings, the steering stems may be different lengths which means you'd have to get the CB stem into the CBR bottom triple.  I'm not saying that's the case, but don't be surprised.
Not to be a Negative Nelly, but there will be issues.  Seemingly simple things like ignition switches or steering stops can make a man batty.
Yes, but how are you going to mate the CB hub to the CBR axle?  Are the axles the same diameter?  If not you'll need to see if you can get wheel bearings that are the correct outer diameter for a CB hub and correct inner diameter for the CBR axle (if they exist).  And you'll need custom spacers.
If you keep the CB hub, are you going to keep the CB brake rotor and caliper?  You'll have to find a way to mount the caliper on the CBR forks.  It may be possible to use the a CBR caliper on the CB rotor, but that will probably need a custom caliper hanger.  You should probably use the CB master cylinder as well, since the CBR MC was designed for dual discs and would be rock-hard with a single disc setup.
If you want to use the CBR brakes, you'll have to find a way to mount them on the CB hub (IIRC, early CBR600 rotors didn't have carriers, they bolted directly to the wheel).
You'll need to make sure the wheel and rim will fit under the CBR fender or figure out how to move the fender.
Decide on the hardware configuration you want and then puzzle out how to get it all together.  Chances are somebody here has done it, or something like it, and can point out the pitfalls before you get to them.
Good luck
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline hyde7278
« Reply #5 on: May 26, 2011, 10:14:12 AM »
By using the HD hub (narrow glide only) it solves the axle issue you will need to have spacers made, for brakes use the CBR's, rotors you will have to find one that have room in the carriers to re drill the mounting holes to line up with the holes in the hub. A few on this fourm have done frt end swaps and you can get ideas from theres, do a search for front end swaps and you will find them. That prob used diffrent front ends but had to overcome the same things you will have to so you should be able to get some good ideas from them.
76 CB550F
