Author Topic: unsteady idle - pics and video.  (Read 966 times)
Offline c(b)hris
« on: May 26, 2011, 02:23:56 PM »
'75 CB550K
Pods
4-1
I just did a 3000 mile tune up.
I'm trying to diagnose my idle problems, so I took these plugs out after I warmed it up.
They're 1-4, Left to Right:
Idles fairly steady for about five minutes, even when it's started after already warming up.  After five minutes, the rpms will become unsteady.  What is this a symptom of?  I sprayed carb cleaner around the boots while it was steady and the idle never changed.  My air screws are 1 3/4 turns out from seated.  I just cleaned my air filters(was doing this before I cleaned them).  Carbs have been synced with vacuum gauges.
Here's my unsteady idle:
Rough_Idle.3gp
Did I screw something up with my tune up?  What is this a symptom of?
Thanks in advance.
« Last Edit: May 26, 2011, 02:25:50 PM by c(b)hris »
75 CB550
74 CB750
Offline Really?
Re: unsteady idle - pics and video.
« Reply #1 on: May 26, 2011, 02:35:36 PM »
I am not a pod guy but do you get fuel coming out of the overflow tubes?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: May 26, 2011, 02:39:19 PM »
Apparent your number 2 cylinder isn't firing off. Got spark? Got gas in the float bowl? Check the exhaust pipe for heat compared to the rest?
« Last Edit: May 26, 2011, 02:41:54 PM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline c(b)hris
« Reply #3 on: May 26, 2011, 02:44:09 PM »
No gas coming out overflows.
I checked 2 for spark before that video and its nice bright blue in the daylight.
Im gonna check the float bowl/pipe now.  Thanks for the tip.
75 CB550
74 CB750
Offline c(b)hris
« Reply #4 on: May 26, 2011, 02:51:47 PM »
All the pipes are hot.
How long would it take the plugs to foul?  Would it make sense that it starts off ok but starts running unsteadily once the deposits build up?
Thx
75 CB550
74 CB750
Offline c(b)hris
« Reply #5 on: May 26, 2011, 03:00:25 PM »
When I blip the throttle I get a little black smoke out the tail pipe.   According to the carb faq black smoke out the tail pipe = rich.  The blip is opening the throttle about 3/4.  I'm gonna lean my air screws 1/8 turn and see what happens.  I'm guessing the needle will have to go a little leaner too since the smoke comes out at 3/4.  Does that sound like I'm on the right track?
Thanks in advance.
75 CB550
74 CB750
Offline phil71
« Reply #6 on: May 26, 2011, 03:09:40 PM »
the sound of the engine reminds me of a vacuum leak. mist some carb cleaner or WD 40 (not ether) at those boots and see if your idle changes.
