Author Topic: 10k resistor wires?!?! 5ohm caps, cap angles??? what?????  (Read 4777 times)
Offline xsmooth69x
« on: May 27, 2011, 03:07:58 PM »
i have a honda 1975 cb550
ive been lurking on archived threads and get different answers every time.
sooooo
where do i get 10k resistor wires..... and what gauge do i need
what caps do i get and why are their so many angles?
what angles do i need?
1975 CB550 (FINISHED?!?!?)
Offline cookindaddy
  • I sure love this bike!
Re: 10k resistor wires?!?! 5ohm caps, cap angles??? what?????
« Reply #1 on: May 27, 2011, 03:16:18 PM »
TT wrote some excellent pieces recently about plugs, caps, wires and resistance thereof. If you find any of his posts in your search you can take them as gospel.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: May 27, 2011, 03:27:59 PM »
Should be 5000ohm caps. NGK makes a couple different angles. I put straight caps on my outer and angled ones (not 90 degree) on my tow inner cylinders. I believe most 7mm wires should work. NGK makes those too. Are you splicing onto existing wires?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline xsmooth69x
« Reply #3 on: May 27, 2011, 03:55:50 PM »
5000ohms  :o ow.....
im thinking about boring out my coils and actually replacing the whole wire..... i mean if that makes a huge difference or should i just use a ngk coupler thing? does doing the splice really hamper the spark?
so straight ones on the outside "angled" on the inside?
« Reply #4 on: May 27, 2011, 05:21:15 PM »
i used four of the same angle with stock wires here,5k ohm,,,you can read the part number on them .
Offline xsmooth69x
« Reply #5 on: May 27, 2011, 05:53:42 PM »
dude you bike is so clean and beautiful it makes me cry.........
thank yyou for the pic
Offline xsmooth69x
« Reply #6 on: May 27, 2011, 06:05:52 PM »
what ngk wires do i get?
do they have ngk wires with the cap already on them?
« Last Edit: May 27, 2011, 06:09:21 PM by xsmooth69x »
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #7 on: May 27, 2011, 07:05:24 PM »
  where did you get those red plug caps, if you don't mind me asking....????
I like berries.
« Reply #8 on: May 27, 2011, 09:00:21 PM »
they came from david silvers gsx69bun,theyre ngk part number XDO5F,stock number 8072,xsmooth the caps have a screw type thread where the wire screws into,your wires are part of the coils,you can snip an eighth inch at a time from the wires untill you come to clean unscrewed around fresh wire,this might be your best course,you can cry again xsmooth i just sold that bike last night.
             heres the short build thread if you want a gander.
http://forums.sohc4.net/index.php?topic=81033.0#lastPost
« Last Edit: May 27, 2011, 09:07:35 PM by dave500 »
Offline xsmooth69x
« Reply #9 on: May 28, 2011, 01:43:14 AM »
dave your a pro man, a pro!
how did you get that engine so clean?
and also you soak parts in molasse? what is that? like the tree sap
« Reply #10 on: May 28, 2011, 02:03:53 AM »
its a by product from sugar cane,,a thick dark brown treacle like goop,mix it about 50/50 with water and it removes rust and smells like rum,tastes like licorice,soaking for a week does the job mostly,its cheap,you can buy it at farm produce supply places.
