Author Topic: Replacing fork seals with air assist  (Read 1732 times)
Offline CJ
  • 1981 CB750 Custom
« on: May 29, 2011, 02:50:51 PM »
Hi, I'm new.
I have a 81 CB750 Custom and the fork seals are leaking. It has some sort of front air assist and I'm not sure how to replace fork seals with that. It has a air valve on the top of the fork and a hose going to the other fork. I've replaced regular forks seals before. Can anyone give me advice on how to replace my fork seals? Thanks.
Offline lone*X
Re: Replacing fork seals with air assist
« Reply #1 on: May 29, 2011, 03:53:04 PM »
If an admin will move you post to the "Other Bikes" forum I'm pretty sure someone will pitch in and give you a hand.  This particular forum is pretty much SOHC only and your 81 is a DOHC.   You may also want to join and post you question to the DOHC forum which is at  http://www.cb750c.com/
Good luck.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline crazypj
  • I'm brill, me
« Reply #2 on: May 29, 2011, 04:10:28 PM »
Replace seals as normal, just let all the air out first
bollingball
« Reply #3 on: May 29, 2011, 04:34:52 PM »
+1 CJ seal change is the same
Also crazy has a point you would probably get more help with people that deal with the DOHC
Offline CJ
  • 1981 CB750 Custom
« Reply #4 on: June 06, 2011, 03:24:19 PM »
Thanks for the help. I was told my bike was a SOHC. I'll try there from now on...Thanks again.
