Author Topic: 73 cl350 Scrambler  (Read 1381 times)
Offline bigragu
73 cl350 Scrambler
« on: May 30, 2011, 04:52:30 AM »
Removed everything on the bike to paint reassembled and now can't get spark to the plugs. Check all my wiring and have power to the electric starter, could the old coils have been damaged in the tear down? They are the only thing I haven't replaced yet?
Offline Frankenkit
  • Industrial Strength
Re: 73 cl350 Scrambler
« Reply #1 on: May 30, 2011, 08:46:23 AM »
Maybe you pulled loose the black/white striped wires going to the cables from the ignition switch?  Just grasping at straws here...
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline bigragu
« Reply #2 on: May 30, 2011, 10:03:28 AM »
Checked everything twice thinking the same thing still stumped.
Offline Frankenkit
« Reply #3 on: May 30, 2011, 10:11:57 AM »
huh.  ok, I defer to the higher authorities then.
1973 CL350- Lola?
Stuff for sale
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #4 on: May 31, 2011, 07:58:46 PM »
If you painted the frame, check that the condenser pack has a good ground. May need to scrape some paint off under the condenser mounting bracket or run a separate ground wire.
Stu
MCN DTF
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: June 01, 2011, 05:30:14 AM »
Also could be something as simple as dirty points, but the ground contact mentioned is a likely problem...Larry
Offline bigragu
« Reply #6 on: June 05, 2011, 04:35:44 AM »
It's funny you guys mention those two things because I have replaced the points and condenser. I found in the points there was a small plastic washer missing inside where the blue wire connects, and the blue wire coming off the condenser was grounding out.
« Reply #7 on: June 05, 2011, 10:54:38 AM »
That would permanently ground that set of points and prevent the cylinder from firing.
Regarding the question you sent me by PM,  That green wire with the female connector on it is an unused ground. Make up a ground wire for the coil bracket, and plug it into that female ground to eliminate condenser grounding issues. Check your PMs.
Stu
MCN DTF
Offline grcamna2
« Reply #8 on: June 07, 2011, 03:17:00 PM »
Check the right handlebar switch (black/white) wire to the kill switch & then check
the switch itself.
Offline bigragu
« Reply #9 on: June 07, 2011, 06:16:27 PM »
Fixed today thanks
