Author Topic: Suspension Help for CL360  (Read 1920 times)
kenifico
« on: April 21, 2006, 11:56:21 AM »
Hey guys. My bike isn't quite a four but I figured you guys knew a bit about the twins honda made. I own a '74 CL360 (who doesn't love scrambler pipes?) that's a little sagging in the suspension department. After reading the shop manual I found that the rear shocks are non rebuildable, the only option would be getting new shocks. Do I have to fork out $400 for a new set from works performance or is there an alternative? Should I look for another set from a donor bike? What bikes have compatible shocks? The same goes for the forks, except I can rebuild them... Should I put in new springs, thicker fork oil? Again, are there better forks I can put on from a compatible donor bike? Thanks for the help guys!
Kenny
Offline dusterdude
Re: Suspension Help for CL360
« Reply #1 on: April 21, 2006, 12:31:51 PM »
not sure what kind of configuration your shocks are,but keep an eye on ebay,they`re all over the place there.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline crazypj
  • I'm brill, me
« Reply #2 on: April 21, 2006, 03:13:55 PM »
They are standard issue Honda, look for 350/400f pretty much the same thing
PJ
Offline cb650
« Reply #3 on: April 21, 2006, 06:12:04 PM »
i have a 76 cb and i know 650 shocks will fit with a little mod to the chain gaurd.  A 1/2 inch longer though.   The shock for a 750 that have been listed lately look like they would work too.  Also the 350 racers might have something.
                 Terry
Offline Bill Vaughan
« Reply #4 on: April 21, 2006, 09:55:40 PM »
Kenny,
I restored a '75 CL360 last year and suffer from the same problem - original rear shocks are weak and should be replaced at some point.
As far as the fork is concerned, I think you'll find that a rebuild will make a big difference in terms of performance.  I replaced the seals, covers and fluid after a thorough cleaning of all other parts, and the front end seems to have just the right amount of response now.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
