Author Topic: My '72 CB500 Project.  (Read 1716 times)
Offline cr8zy1van
    • www.slopescience.com
« on: May 31, 2011, 10:35:15 AM »
Morning.
I finally found and picked up a CB500 that I want to chop into a smallish racer. $300 at a local bone yard, it kicked over but the carbs are totally fouled up, and the ignition is shot. Mechanically the bike seems sound, no missing parts and hardly any rust. This will be my first bike build... but I guess I have to start someplace.
As for my plans with it... keep it affordable! Make a fun around town daily commuter but still have fun with it. I am cruising around on a 74 Yamaha DT125 Enduro right now, so this will be a welcome upgrade. (go ahead and make scooter jokes... it gets 100 mpg) The Enduro will be handed down to my GF until I can find her something fun.
I have noticed a couple really cool cafe racers/chop jobs around Salt Lake City and have been trying to get in touch with people that love old bikes. Any forum members from around these parts?
The bike as I found it. Mostly there, electonics shot but the motor kicks over, and it had oil in it. I dropped the pan after getting her home and inspected for any metal shavings or pieces.  Last time bike was registered was in 09, so I reckon it has been standing for at least a couple years.
Got her home and started stripping her down. I am keeping all the parts in a bin, but will probably try to replace that tank with a Super Sport or something more flattering.
 Took the motor out and have just the rolling chassis today. I don't have clipons or clubmans just yet, so just flipped the original bars so I have something to steer her with.
 The carbs seem to be in bad shape. Lots of gunk and the guy that rebuilt them last had parts in the wrong places.... I checked the manual and will correct when I rebuild. I have since cleaned it but am waiting for ideas on coatings before I reassemble.  Saw someone use baking soda and a compressor to bring a little shiny back... does anyone have experience with this? I played around with anodizing at home, but I didn't like the result.
 Nothing but the frame left. Hardly any rust! A little surface flakes next to an engine mount but I can deal with that. I also cut off the passenger foot pegs, but realize I will now need to fabricate something to mount the MAC exhaust onto.
 Measured and marked where I am cutting the frame. This was a big deal for me since I have always been told don't mess with a good frame! I want to shorten the frame a little and put a nice metal hoop in.
No going back now.
 Found a hoop that fits perfectly! I don't have a pipe bender (or welder for that matter) so I had to scavenge something I could use.
 Home Depot welder and a little practice! I haven't welded for 10 years so it looks a little crusty. I ended up smoothing and checking all the welds once I was done. Also added some sheet metal for a nice seat base.
 Closeup of the tail.
 Glued up some pink foam and carved a quick seat. I am replacing this tank, but used it to see if I could tap in the sides for that cafe look. It was actually really easy and a few layers of bondo would make it look fine.
 Side profile with mocked up seat and old tank
 I found a CB400 Super Sport tank today. After mounting it and extending the seat  to match (at this point it has been covered with bondo and smoothed) I realize it is too short. I guess I will keep looking for a 750 tank, or make something from scratch. I have been doing research on fiberglass tanks and they don't seem to do so well with ethanol and gas.... anyone out there with any suggestions?
 New tank and seat plug from the side.
So I have had the bike for about 3 or so weeks by now. I would like to have her up and running sometime this summer and maybe stave off rebuilding the motor if I can get it to run. I will get the compression tested, and order up ignition coils and maybe a new electronic ignition.
Offline cr8zy1van
Re: My '72 CB500 Project.
« Reply #1 on: June 02, 2011, 11:02:28 AM »
I sanded the plug down to smooth it out and want to start finalizing the shape... but will have to wait to find a longer tank. As it is now I probably want to take 4 or so inches from the front of this seat. (roughly where the sharpie line is. ) I do plan on making a full female mold so hopefully I can layup a nice piece. I have a friend riding a CB350 that also wants a tail, if it fits I'll make him an extra.
Offline Sheik Yerbouti
  • Likes the warm feeling but is tired of all the dehydration.
« Reply #2 on: June 02, 2011, 11:12:17 AM »
The bike already has great lines. Hell, I like it a lot with the 400 tank on it. Keep up the good work!
Offline cr8zy1van
« Reply #3 on: June 05, 2011, 09:05:10 PM »
The red CB400 tank was way too small and short for my liking. After not finding one that I could modify, I decided to build a plug, and layup a custom tank... here goes.
The block of foam I stuck together with liquid nails... there has to be something better to glue large surfaces, it makes carving a pain. My folder with ideas, kinda thinking of modernizing the old tank shown.
The rough shape is taking form. I want something akin to old 750 racing tanks, with knee indents and a nice round shape.
I had to fit and carve more and more as I zero'd in on the underside of the tank. I will be using thick plasticine clay to layup the shape for the bottom of th tank, right on the frame, so this is really just to get everything in place. Still mounted the rubber bumpers, and ignition coils just to make sure everything fit.
Glue'd the form in place with bondo mixed a little warm. Held everything in place to make sure it didn't shift while I was moving around.
Also decided to fix a couple low spots that were sanded down to the foam on the seat. Took nice chunks out and then filled and re-surfaced the seat.
Sanded the plug smoother. I will be spending a little time over the next week while girlfriend is gone perfecting this. A few spots are still low and then its not 100% symmetrical. Right side of tank needs to be filled up a little as well as knee dents smoothed.
Put about 9 hours into it. Adding bondo, smoothing a little, then adding bondo again. Its only my second time ever using the stuff, but I think I am getting the hang of it. The tank and seat will be separated once I am done smoothing and sure everything looks nice.
maduncle
« Reply #4 on: June 05, 2011, 09:53:03 PM »
You are doing an amazing job on that seat pan and tank shaping.
I wonder if there is any way you could leave the two of them joined together? I like the one piece look.
Great stuff!
Offline Bunicula
« Reply #5 on: June 06, 2011, 11:06:56 AM »
wowzers :o thats some great work.. ill def be watching this one
Offline Toxic
« Reply #6 on: June 06, 2011, 11:27:32 AM »
For a guy that has only used this stuff twice ... that's quite amazing.
Good job, keep the pics coming
Offline Bakeoff
« Reply #7 on: June 06, 2011, 12:02:55 PM »
Love it!
