Author Topic: Head Buffeting with a Windsheild  (Read 694 times)
« on: May 31, 2011, 12:05:41 PM »
I bought a 15” Spitfire Viper windshield since the wind was beating the hell out of me on long runs.
I mounted it according to instructions and headed out. I have a quiet rod with long straightaways
a few blocks from the house. When I hit around 50mph my head was buffeted enough to make my vision blurry.  It was not the windshield that vibrated it was my head.
I changed the angle of the shield, the height, with the same results. The only thing that helped was to grab the top of the shield and bend it down. Anybody have experience with windshields and this problem. I am only 5’ 8” so I am not sticking up way above the plastic.
Offline Really?
Re: Head Buffeting with a Windsheild
« Reply #1 on: May 31, 2011, 12:11:53 PM »
Don't know if this will help but I would get head buffeting behind a shield and found that if I had the vents open on top of the helmet it would do this.  Closing the vents on the top of the helmet took care of a lot of it.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline tramp
« Reply #2 on: May 31, 2011, 01:08:55 PM »
did you change your position on the bike
if that works you have to play with the windshield
1974 750k
« Reply #3 on: May 31, 2011, 01:20:43 PM »
Yes I tried different positions. Laying on the tank was good. Poking my head out the side past the shield was good also. If I stand up it is OK also. I adjusted the brackets to tip it back, forward, up down etc.
Offline Kevin D
  • SE Michigan
« Reply #4 on: May 31, 2011, 03:01:23 PM »
It happened to me just the same on the rental Road Glide with shorty windshield. It was worse when following other riders, better when leading or at some other speed....... like a jackhammer on my temples.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: May 31, 2011, 03:04:55 PM »
Do you have much room for adjusting the height?  I'm about the same height as you and the 17" windscreen I use on my 750 in the Winter is the perfect height.  The top edge sits below my line of sight, but it sends the air just over the top of my helmet.  If it were an inch or two lower I would have the same buffeting problem.
« Reply #6 on: May 31, 2011, 04:11:20 PM »
Gordon, what brand and model are you using?. I will see if I can return this one and get another.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: May 31, 2011, 05:15:33 PM »
Mine is the National Cycle brand "Street Shield".
I lucked out in that it came with one of the bikes I bought years ago, and it just happens to be the perfect size for my needs.  If I hadn't happened upon it I may have ended up spending a lot of money trying to find just the right one.
