Author Topic: CB400F Dyna Electronic Ignition and 3.0 ohm coil upgrade problems  (Read 963 times)
Offline ritchystyxx
  • I am The Test Rider.
Hi,  Should I expect problems to come up with my electrical system after I install the Dyna DS1-1 Electronic Ignition and 3.0 ohm coils?  Would I need to upgrade other parts of the electrics?  Battery, Fuse box, Rectifier?  Anyone still doing the oil pump mod to increase the oil pressure?  I am looking to see 105mph and with the stock setup, I'm at 101mph so far and am 190lbs.  :D
Thanks for any help,
Ritchy
PS.  What are the chances that I will see problems with using the 3.0ohm coils vs. the 5.0ohm?
« Last Edit: May 31, 2011, 05:09:13 PM by ritchystyxx »
"We're not here for a long time, we're here for a good time." -Guy Martin
Re: CB400F Dyna Electronic Ignition and 3.0 ohm coil upgrade problems
« Reply #1 on: May 31, 2011, 05:40:15 PM »
Did you remove 60 watts of electrical load from the bike to compensate for the extra draw of the Dyna?
bollingball
« Reply #2 on: May 31, 2011, 06:11:26 PM »
Yes you should expect and will have problems. You should have ask sooner. If I were you I would put the coils up for sale and get the 5ohm ones. But that is just me others will say different.
Offline jaguar
« Reply #3 on: June 01, 2011, 12:10:40 AM »
why not use the hondaman resistors?
