Author Topic: hondaman ignition instructions?  (Read 945 times)
Offline many408
« on: June 01, 2011, 09:45:02 AM »
Hi all, have one of these to install but no instructions; I emailed Mark but no reply...
All I need is what colour wire on the box goes to what colour wire in the harness.
bollingball
Re: hondaman ignition instructions?
« Reply #1 on: June 01, 2011, 09:56:17 AM »
many: I;m sure Hondaman will jump in as soon as he reads this. I don't have the unit yet but soon will I do have his book and it has some info on it. The colors should match up. What bike do you have. does the unit have a 6wire M/F plug or is it bullet connectors? Give a little more info. and I will try to help>
                         Ken
Offline many408
« Reply #2 on: June 01, 2011, 10:40:23 AM »
Bullets, target is 400f.
Offline many408
« Reply #3 on: June 02, 2011, 07:56:42 AM »
Nevermind, found this about 20 pages deep in the search results here:
Black - splice between black/white feed to coils, this powers unit.
Green - to ground on points plate
Yellow and Blue - to points
Orange to Yellow coil, Violet to Blue coil
I decided the simplest way to deal with the different-size bullet connectors was to make three Honda-female-to-bigger-male adaptors; I used a dremel to widen the slit in the extra females he sent, then squeezed them down to grip the Honda males, and just soldered them to the big males.  The big male-ended wires I just shoved in the Honda females, which can be road-side-squeezed to re-insert the Honda ones if necessary.
