Author Topic: how do i hotwire my cb750?  (Read 3338 times)
Ceej
« on: April 22, 2006, 10:52:50 AM »
No im not a thief!!!
I am trying to solve my electrical problem, and im pretty sure i have checked all the possible fuses/connections.  So I hope i have narrowed it down to my ignition switch, before i go and get a new one, i want to make sure.  So if i hotwire it, this will bypass the ignition switch, right?  Will doing this cause any possible harm?
Offline Ted Nomura
Re: how do i hotwire my cb750?
« Reply #1 on: April 22, 2006, 01:40:13 PM »
Fuses on CB750s are fragile, especially the early units which had no back-up. It's safer to get a new ignition switch. They are not expensive.
1969 Honda CB750, two 1970 CB750, two 1972 CB750K2, 1971 CB500, 1975 CB550, 1976 CB400F, 1968 CL450, 1973 CL450, 1974 CB450, 1970 1/2 SL350K1, 1971 SL350K1, 1972 SL350K2, 1972 CL350, 1972 CB350, 1983 CB1000C, 1976 Kawasaki KZ900A4, 1976 KH500A8, 1979 KZ400B, 1983 ZN1300, and so on and so on...
Ceej
« Reply #2 on: April 22, 2006, 02:23:23 PM »
well, before seeing your reply, we tried a jump, and found that the ignition switch was bad.  But we also created a new problem.  The starter will not stop running.  Whenever the battery is connected, the starter is constantly running.  Any ideas on this?
« Reply #3 on: April 22, 2006, 02:35:44 PM »
The ignition switch simply connects the battery to the Black wires on the bike.  A jumper works as well or better than the switch.
The starter button can be damaged.  Or, the starter solenoid could be stuck.
I you remove the Y/R wire from the solenoid and it still exhibits the same behavior, replace or overhaul your solenoid.  Otherwise, check your starter button.
You should include year and model in your problem description. CB750 applies to 11 or 12 years and models.  Many have different wiring nuances.
Ceej
« Reply #4 on: April 22, 2006, 03:18:58 PM »
yeah sorry i forgot, its a 74, but I figured it out, Stuck solenoid.  THanks for the help
