Author Topic: cb550 air cleaner chamber drain hose?  (Read 1552 times)
Offline twallace
« on: June 04, 2011, 10:01:09 PM »
Is the drain hose at the bottom of the bottom of the air cleaner chamber suppose to be closed or open at the end? Does it make a difference?
Was doing some poking around down there and the drain hose was in bad shape (wrapped with electrical tape?) and a cap on the end was hanging on by a thread. Going to replace it with some tubing but wasn't sure about the cap on the current one.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: cb550 air cleaner chamber drain hose?
« Reply #1 on: June 04, 2011, 10:59:05 PM »
I've taken the end of a camelback drinking tube and siliconed it to the drain tube. It doesn't let air in and you can squeeze it to drain condensation. just like Honda intended.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline SohRon
« Reply #2 on: June 05, 2011, 11:13:19 AM »
The tube from the plenum (still available) is open, but includes a foam screen in the end. The hose from the bottom of the Air cleaner housing is essentially the same tube, but originally was plugged with a slotted cap. Naturally, this is no longer available
 I just bought two of the tubes, then cut the one for the cleaner housing to length and plugged it up with a small plastic plug. It's a drain for the cleaner box that needs to be cleared occasionally, so the plug must be removable.
Hope this is what you're looking for.
« Last Edit: June 05, 2011, 11:22:26 AM by SohRon »
« Reply #3 on: June 05, 2011, 11:20:54 AM »
Tube should be capped to prevent air entry.
The stock tube cap has a slit in it so that liquids can weep out when there is no negative pressure in the cleaner system.
The cap can be pinched to open the slit, and allow anything collected to drain out rapidly.
