Author Topic: 750 carb question on float bowl vents  (Read 1363 times)
Offline Steve_K
« on: June 05, 2011, 03:28:13 PM »
I am rebuilding my 750 carbs (657A) with a few parts from a (657B) rack. I noticed on both carb racks that in the #4 carb one of the brass inserts was missing in both carbs and no where to be found.  I will try them with out it, but did a PO do that or did Honda do it at the factory.  I have a pic with a an arrow pointing out the missing (?) brass part.
Do I need to try to find another #4 carb?
Steve
Steve_K
Offline Johnie
Re: 750 carb question on float bowl vents
« Reply #1 on: June 05, 2011, 03:41:14 PM »
That is normal. Mine are the same way. That is a Honda thing. Not really sure why, but I also looked at a few extra carb racks I have here and they are all the same. Good luck with your build.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Steve_K
« Reply #2 on: June 05, 2011, 04:55:29 PM »
I thought it was weird that both were that way. I am doing a 73 750,  planning to make it my touring bike, after I fix the electrics, the bearings, the forks, and on and on.  Thanks for the response,  I can finish the carb rebuild.
Steve
Steve_K
« Reply #3 on: June 05, 2011, 05:06:47 PM »
The carb bowls have interlink tubing between them to vent the bowls. #4 only links up on one side of it to #3.
Offline Steve_K
« Reply #4 on: June 05, 2011, 05:22:58 PM »
The brass insert that is there goes to the linking tube as you say.  I am curious that the other 3 carbs have two inserts.  The #1 carbs in both racks have two inserts.  I would have considered Honda to be more consistant in this.
It is all part of the fun and challenge to make these bikes sing again.
Thanks for your response,  I appreciate it.
Steve
Steve_K
