Author Topic: timing with gun  (Read 4473 times)
Offline c(b)hris
Re: timing with gun
« Reply #25 on: June 10, 2011, 06:52:19 AM »
Love the title Chris, makes it look like that you got fed up with trying to tune it and just shot it..... :o ;D
lol.  next is carb tuning with a gun.
replace all the tiny screws while your at it,improves accuracy if your not slipping and fumbling with worn out screw heads.
will do.
75 CB550
74 CB750
bollingball
Re: timing with gun
« Reply #26 on: June 10, 2011, 08:32:30 AM »
Little allen heads are great. doesn't slip off so easy like the JIS driver does.
                                   Ken
Offline c(b)hris
Re: timing with gun
« Reply #27 on: June 11, 2011, 09:49:30 PM »
Okay, the new points seems to have cured the problem with the erratic flashing of the timing gun whether it was the root of the problem or not.
Idle timing is right on for 1.4 and 2.3, and advance timing is right on for 2.3, but advance for 1.4 looks way off.  The two advance marks for 1.4, which as I understand are supposed to line up so that they are on either side of the timing mark, are way to the right of the timing mark.  So...
______________
______________
I've read in other posts that I should set my advance timing to be right on, and accept the idle timing being a little off.  Does this sound right?
Thanks.
75 CB550
74 CB750
Re: timing with gun
« Reply #28 on: June 12, 2011, 12:46:17 AM »
set it at the advance,both 1/4 and 2/3 should be the same.
Offline c(b)hris
Re: timing with gun
« Reply #29 on: June 12, 2011, 07:46:53 AM »
Cool..  thanks very much.
75 CB550
74 CB750
