Author Topic: Universal regulator and rectifier fits honda 4's and yammie twins!!  (Read 2653 times)
Offline c_packer
I cant figure out what the two orange wires are for ign 1 and ign 2.
« Last Edit: June 07, 2011, 08:32:13 PM by c_packer »
I'm a creep, I'm a weirdo. What the hell am I doin' here? -Radiohead-
Offline c_packer
Re: Universal regulator and rectifier fits honda 4's and yammie twins!!
« Reply #1 on: June 06, 2011, 08:04:35 PM »
I forgot to mention the part number is Transpo S1003uh paid 35 bucks on eBay.
« Last Edit: June 07, 2011, 08:31:18 PM by c_packer »
Offline Bodi
« Reply #2 on: June 13, 2011, 07:03:05 PM »
See if those two orange wires are connected together inside the unit. If so just use one and tape up the end of the other.
The bigger mystery is the single field coil wire. You may have to ground the other field coil wire or connect it to +12V. There should be some instructions i think!
Anyway you can test it with a tail light bulb. Connect all the wires except the green one. Connect the bulb between the green wire and ground, then between the green wire and +12V. Whichever way lights the bulb when you turn the key on is the proper connection, just wire in the field coil in place of the bulb.
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #3 on: June 14, 2011, 07:31:37 AM »
The wire descriptions don't match the colors in that drawing. If the unit looks just like the picture, that's a regulator/rectifier for a permanent magnet style alternator, not for one with an excited field. What year and model is your bike?
Stu
MCN DTF
