Author Topic: Which 836 kit do I have?  (Read 2037 times)
Offline karmasevo
« on: June 07, 2011, 12:31:00 PM »
First I apologize but I am a bit of a newb. Been buying new bikes my whole life and finally decided to start building my own stuff. I bought a 1974 CB750 last week. Has an 836 kit in it and runs awesome!. Issue is that the guy I bought it from did not do the 836 kit. It was the guy before him. He has no idea what pistons were used and therefore what compression ratio the pistons are. what is the easiest way for me to figure out the compression ratio of the engine as it sits. I want to do head work, lighten the crank, ect. But would like to know where I am starting from. Thanks in advance for the help.
  • Moderator
Re: Which 836 kit do I have?
« Reply #1 on: June 08, 2011, 03:54:09 AM »
Welcome Karma, you won't really know till you pull it down. If it runs well on pump gas, chances are the pistons are around 10 to 1.
Post some pictures of them plus any markings that might be on them.
Sam. ;)
Offline turboguzzi
« Reply #2 on: June 08, 2011, 07:19:06 AM »
Sam. ;)
"untill you pull it down"?
Sam, from you, the HiPo master? :)
Place piston nr 4 at TDC, valves closed, lean the bike pretty far on it side (rest on an old matress or something soft and thick), take a burret to measure the quantity of oil needed to fill the combustion chamber till the plugs thread.  ((836/4)+CC volume) /CC volume = CR
TG
  • Moderator
« Reply #3 on: June 08, 2011, 08:47:14 AM »
Ever so sorry Yossef, I'm tired and didn't read it properley :-[. Thought he wanted to know the comp of the pistons. ::)
Sam. ;)
Offline karmasevo
« Reply #4 on: June 09, 2011, 12:43:37 PM »
Sam. ;)
Wow, That doesn't sound tough at all. Thanks a ton!
Offline Tintop
« Reply #5 on: June 09, 2011, 04:42:14 PM »
Easy yes, but make sure you get the oil back out before you try turning it over.  Otherwise you will get a hydraulic lock, and bent parts.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline turboguzzi
« Reply #6 on: June 10, 2011, 05:45:10 AM »
Sam. ;)
now that you are wiser, do some search on "measuring compression ratio" and sure, dont forget to suck the oil out from that piston!!!
Have a look at pics of the underside of a 750's head to understand better which way to tilt the whole bike so you trap the least amount air while you are measuring
Offline karmasevo
« Reply #7 on: July 05, 2011, 02:01:10 PM »
will do thanks a lot to both of you. Sorry it took me so long to respond. I just got back into country a couple of days ago. Thanks again!
