Author Topic: Bringing her back to life - '73 CB500 - with questions  (Read 3491 times)
Offline vintage_mpg
Re: Bringing her back to life - '73 CB500 - with questions
« Reply #25 on: July 06, 2011, 04:09:18 PM »
Larry (and anyone else who might have a suggestion...) -
Here's what I'm seeing...
I pulled the carbs with a minimum amount of swearing.  I started on the first carb, popped the top cap and worked through the long list of steps to get that long needle valve out.  It was perfect, with NOTHING on it that looked grimy/slimy/otherwise.  Took me an hour to get it apart and back together again.
I pulled the float bowl and took apart the part of the slide with all the holes.  It was clogged city.  Great call Larry.
Additionally, the tiny "plug" that sits beneath the slide with all the holes (how about those technical terms!) was plugged.  I soaked them in carb cleaner and blew them out.  I've done three of the 4 carbs and found the same thing each time.  You nailed it on this stuff, Larry.
Here's what I'm wondering: do I need to pop the top caps on all 4 carbs to clean the actual needle jet?  It was remarkably clean, and there's really nothing going on up top except the sliding of that needle valve.  I'm thinking that the lion's share of the problems are in the clogged holes on the lower slider (accessed via the float boat).  Not taking out the top portion of the needle would save me some serious effort (that felt like doing open heart surgery with all those tiny parts laid out everywhere!).  I'm afraid I'm going to muck it up with all that tab bending, slide pulling, link removal, etc.  The real breathing happens in the bottom portion anyhow, correct?
Here's what parts I'm talking about...
Offline vintage_mpg
« Reply #26 on: July 06, 2011, 09:26:46 PM »
I've answered my own question: YES - just spend the time on the bottom portion of the slides - and you'll be in business!
AMAZING call, Larry!  I cleaned up all the carb components you suggested - and just like that - she's running like a champ.  Screamin' all the way through the powerband, good as new.
I appreciate your help so much!
She's going to need fresh treads and then it's time to start killin' bugs.
I'll probably get her cleaned up and ready to sell, and start looking for the next project...life is good.
What's better than time resulting in the target you were aiming for?  I love that!
Offline MoMo
  • Ride like you're invisible
« Reply #27 on: July 06, 2011, 09:52:10 PM »
OK Larry - I'm back in town and about to yank the bank.  That's the bank of carbs...
When (not if!) I run into a jam, I'll shoot you a PM.
Sound good?
That is fine with me...Larry
Here goes nothing...
