Author Topic: Replacement SS Allen bolts from alloyboltz - CB500/550  (Read 1445 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: June 08, 2011, 07:51:16 AM »
Just an FYI - there are four 6x20 bolts that go on the front of the valve cover (P/N 93500-06020-0A ) and their Allen heads are too tall to allow the tappet caps to be screwed in properly. You'll have to get four flat-head replacements to obtain adequate clearance. Found this out yesterday after spending an hour sorting the bolts out and torquing them down.
Otherwise the alloyboltz kit (from ebay) seems to be a quality product and even includes instructions for properly torquing ss bolts with anti-sieze. The 6mm bolts have a "wet" torque value of 4.4 ft/lbs as opposed to the ~5.6 ft/lbs listed in the manual. The torque wrench I'm using is in inch-pounds though, so that's 52.8 in/lbs.
Offline mitch500
« Reply #1 on: June 08, 2011, 09:31:56 AM »
Had the same problem with theSS kit. I put the tappet covers on first, then the bolts could just squeeze past with a bit of resistance.
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Replacement SS Allen bolts from alloyboltz - CB500/550
« Reply #2 on: June 08, 2011, 10:30:20 AM »
I thought about that but didn't want to have to undo them if I ever needed to readjust the tappets.
Offline xsmooth69x
« Reply #3 on: June 08, 2011, 04:17:51 PM »
have you contacted the seller and told them about it?
1975 CB550 (FINISHED?!?!?)
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: June 09, 2011, 10:49:56 AM »
I did - emailed them yesterday on ebay. They said they'd sold hundreds of kits and hadn't had any complaints.. Likely that most users just put the caps on first as suggested above.
