Author Topic: cb550 four with slipping clutch  (Read 1297 times)
Offline crobar
« on: June 08, 2011, 09:57:29 AM »
The clutch is slipping on my 78 cb550 four.
I bought it a few weeks back, it's been running pretty well but before tune-up had been sitting since 1998.
Originally the clutch didn't engage till the lever was almost all the way out so i adjusted it at the lever because i kept stalling it. It's been fine since then but the other day I was riding and when I went up hill or tried to accelerate while at high speed already, the clutch would slip and then re-engage once i let off.
i know there are other ways to adjust it but don't know how, or i may need some new springs or a new clutch.
any ideas? thanks
Re: cb550 four with slipping clutch
« Reply #1 on: June 08, 2011, 10:06:42 AM »
Download the manual for adjustments, but basicaly there is a mark on the operating arm that should line up with a mark on the casing when lever is lifted to cotact point
Offline crobar
« Reply #2 on: June 08, 2011, 01:49:02 PM »
will check that out, thanks
« Reply #3 on: June 08, 2011, 01:56:31 PM »
Some motor oils will cause the clutch to slip.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: June 08, 2011, 02:04:35 PM »
A bad cable will do the same. If it's sticky or corroded inside the sheath your clutch won't engage quick enough. I jst replaced mine it was like having a brand new clutch.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline P_Camps
« Reply #5 on: June 08, 2011, 02:29:13 PM »
I have the same bike and
I've just gone through this exercise.  New clutch plates and springs solved the issue.
1978 CB550
