Author Topic: 1980 CB650 Custom Electrical/Regulator problems  (Read 769 times)
Offline ABikeNamedTrouble
« on: June 08, 2011, 03:43:32 PM »
Hey folks,
I imagine the answer to this question will be "you need a new rotor" but before I bite that bullet, I'd like to get a few more opinions.  Anyway, here's the situation:
I just got my 1980 CB650 Custom back it good order (full top-end rebuild, carb restoration & tune, etc.) and I've discovered a weird electrical issue.  My battery is brand new, reads ~11.8 V at idle, ~13.5 at 3000 RPM and tops out at ~14.5 at 4500 RPM or above.  So, from that, I assumed my charging/regulating system was fine.
But then I stalled out (my fault; I'm a bit of a noob rider) starting uphill and when I tried to restart it my battery was completely dead.  After jumping the bike from my girlfriend's car and recharging the battery, everything seems fine again.
I would dismiss it as a fluke, but I also noticed that the yellow-bundle connector between my R/R and wire harness is melted together, and I can't seem to get consistent readings with a multimeter from the yellow leads to ground.
Any idea what might cause this?  The PO mentioned he had replaced the R/R once and had it go bad again, but during the rebuild I attributed that to a cracked ignition coil (figuring the short was frying the R/R).  But now I'm stumped...
- Adam
1980 CB650c Custom
Keihin PD mechanical carbs
Stock air box and 4-4 exhaust
http://forums.sohc4.net/index.php?topic=97504.0
Re: 1980 CB650 Custom Electrical/Regulator problems
« Reply #1 on: June 08, 2011, 11:06:50 PM »
If it were me, the first thing I would do is get an accurate resistance reading across the slip rings of the rotor.  Or, at least, the wires the go to it disconnected from the R/R.  Something in the range of 4.5 to 6.5Ω would put me at ease. (after subtracting out meter lead resistance)
